Good morning Gents, 1st post here.
I am a training Horolologist from London.
I picked one of these up last week and have tried it with some warm soapy water on some bracelets. So far so good.
I have to order some ultrasonic cleaner and rinse, any recommendations?
Cousins, Gleaves or eBay are my preferred suppliers.
Welcome to the house of knowledge Jaycey. This place is full of people with a wide and diverse knowledge of Horology who are more than willing to help others.
Regarding your question on cleaning solutions, if you use the search function I'm sure you will find many articles on the subject. You will find this at the top right hand of the screen.
Hello Jaycey,
Welcome to the forum. The cleaner and rinse largely depends on what you are going to clean but I am just a hobbyist and I clean watch parts in naphtha then rinse them in 100% isapropanol. I put the parts in small lidded jars and stand them in the cleaner with only water in it and so far I have had no problems. There are loads of specialist cleaner and rinse fluids you can get but hopefully one of the other chaps or chapesses can advise. Oh well back to the decorating - nearly done thank god.
Cheers, Vic
Hi Vic,
how long is this thing going to take you my friend? We miss you here! :)
Cheers
Bob
PS. At least post some pictures of the beers you are using during your decoration! :)
Edited by bobm12
Just finished Bob,carpet gets fitted throughout the house tomorrow and then the furniture goes back into the house. Found solace at the end of the days with Guinness, Coors Light, but mainly Abbot ale and occasionally an odd malt whisky and if I am honest last night a treb drambuie on ice.
May be cracking a bottle of Tattinger tomorrow as my daughter has returned from Venice. Whilst there Much to my delight I got a text from her partner asking permission for her hand in marriage and she accepted. Must admit that it was quite emotional thus the large Dram.
Have missed my watches but have plenty to keep me going when things settle again and have most certainly not lost interest and look forward to conversing again.
Cheers Mate,
Vic
It's good to hear that you have just about completed the DIY Vic, we've been missing you. Enjoy your well earned beers!
  • 3 months later...
My first cleaning machine had to be a cheap affair; so I took one disused ultrasonic toothbrush, filed flat the end of a brass rod, attached with Araldite and cable ties, soldered on a bent pice of flat brass plate at the business end to transfer ultrasonic vibrations to the liquid, and hey presto... I clamp it in place above each jam jar in turn, 9 minute clean, 2 x 3 minute rinses. Although it's only been through it's paces once it seems to be effective.
I like the idea for a fist try! I believe the flat end also agitates? In any case, it demystifies the ultrasonics out there and open a new groove in my brain! Thanks! I'll be following to see further developments and hopefully I could contribute at some point!
Cheers,
Bob
Sonic toothbrushes:
20hz - 20khz
Ultrasonic baths:
20khz - 400khz
"This one goes to 11" = 31khz
Yes Bob, agitation is the main aim.
thanks fellas.
Tim
Edited by tpt
Well, no it appears, upon reading more info; it's 'sonic' not 'ultrasonic' @ 20khz. 31,000 oscillations per minute.
Thanks for the tech knowledge Roberto.
It does seem to help the cleaning though.
What extra cleaning properties does going 'ultrasonic' bring to the job?
cheers
Tim
Would you mind also giving me an idea on the indicators to the right time to refresh the cleaning and rinsing solutions please?
I'm assuming I can do several washes before refreshing it?
thanks
Tim
thanks
Tim
You can clean many times but it depends on what you are putting in - how dirty the items are. I don't count, you just get a feel for when the solution is no longer effective. And when the rinse is no longer effective you will notice immediately.
I have a counter unit next to my L&R that I took off an old printing M/C. I was told approx. 25 washes. As Mark states it depends also how dirty the movements are. I made a mistake a while ago I put some very dirty clock parts that had been sprayed with WD40 through the L&R and it ruined the cleaning solution.
10 cleaning cycles or 1week,afterwards you need to exchange them
If the movements are very dirty even before that
br
emso
p.s: sent from my s****y phone so sorry for typing mistakes
  • 2 months later...
Hi guys, would love to pick your brains a little about ultrasonics. Is it the same as most rules in life 'you get what you pay for' or will a £69 ultrasonic be just as good as £300 machine. After all they both essentially do the same thing. When purchasing, what am I looking for in terms of power/watt etc? Does anyone recommend a particular one etc.
Do the cheap ones have temperature control?
This the one off ebay £60 think it's coming from China dc80082d7813dccb5b0ccd1fb5e7bee9.jpge7c8f5acef59fe670a0a8e01d1110a47.jpg
Sent from my GT-I9505 using Tapatalk
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
