Old HAC Clock
Michael20
Hello all, this is my first post here so I hope I don't break any rules. I have recently bought an old HAC clock on eBay, just to gain some experience rather than as a serious restoration project.  The case is a total wreck but I cleaned the movement and it is now keeping really good time. I guess I am not the first person to fall for this because now its running, I can't resist the challenge to try to get it back to its original state, my problem is finding parts. The front door / glass is missing and there is no key and pendulum. If I could find a similar clock on eBay I would at least have something to go on  but after several days searching I have drawn a blank. I'll attach a few pics in the hope that someone has one on the shelf at home (bit of a longshot I know) also it would be nice to know the approximate age if anyone has any info on that.
Thanks in advance
Michael
Hi and welcome to the forum,  glass if it’s flat can begot from any glazier, if domed that’s a challenge but can be usually sourced on eBay. The same applies to movements which also appear for sale, ihave a few old clocks in the work shop and will have a look.
the case although looking rough will respond to cleaning and a littleTLC.  With rough cases very fine wire wool and methylated spit its work well in removing old and dirty varnish.  Plenty of books on the subject  and clock repair should you require some recommendations just ask.
H A C stands for Hamburg American Clock Company.
So it is after 1900 probably around the WW1 so 1914. Looks to be a 30 hour movement going by the spring. The hands are odd the hour is in the style of what is called moon the minute is what is called Spade. All wood case and the inside is still very rough which is what you would get.  Needs a lot of T L C. With the internet you should be able to pick up a pendulum and you might be lucky with a bezel.
Thank you everyone for your responses. Regarding the pendulum, I had assumed I needed to get the correct weight pendulum bob, so it seems I have some reading to do. Thank you oldhippy, the date is nice to know. I hadn't noticed the hands were odd, again some reading required. The case needs to be completely dismantled and reglued as it isn't square and there is surplus glue oozing from every joint. I have seen a few pendulums that would fit but wanted to find an original if possible. The bezel has defeated me so far but if I can find a picture of a complete clock it would improve my chances. I'll post the pictures as requested by watchweasol  in case that helps.
Hi. Had a look in the shop no HAC MOVEMENTS several three train and two train,no good to you for parts.  looks like the bezel is 120 mm. measure the edge to edge with a vernier,to be  more accurate. Whether the glass is flat or not when the movement is in its case put a steel rule across  9. To. 3 and check the hand height. Clearance above the hands  you could get away with a flat one, no clearance you need a domed glass.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
    • An amazing way with words, I laughed so loud the neighbour's dog started barking 😄. At last we have a new term for " watch breakers "  curtesy of John........." Prior Idiots "...I think it is perfectly fitting, I can't wait to use it 😅
    • Yes, attempts for undoing prior idiots wrong doing,  in inexpensive watches is common.  Regs
