Hello mainspring experts.  I am beginning to put together a Seiko 4205.  I am ready to replace the mainspring into the barrel.  I want to confirm the proper Bergeon arbor, barrel and hand direction.  I have measured the inside of the barrel and it is 7.0mm.  If I read the Bergeon size chart I should use a 6.5mm or #2 size which would fit inside the barrel  Also I believe this is a right hand wind.   Any input would be appreciated
Most springs are clockwise (right handed), but this is an anti-clockwise spring (left-handed). A Bergeon No. 2 is ideal for this. It has to have the blue dot on the winder and not the red dot, which denotes using for an anti-clockwise spring.
Right-hand (clockwise spring) winder has a red dot and left-handed (anti-clockwise spring) has a blue dot.
The reason I call it a anti-clockwise spring is because the direction of the spring from the central arbor is anti-clockwise, or comes out from the arbor in a left hand way. I think calling the spring left hand and right hand are really confusing, rather than clockwise and ant-clockwise, but that's just me.
I hope this helps
Edited by Jon
Thank you very much Jon!  I find the right and left quite confusing.  By any chance do you have a photo of a clockwise/right hand  that I could view.  I do better with pictures..
Mark
this is an anti-clockwise winder
And here is a lesson slide with a clockwise spring
Edited by Jon
I struggled also, I have a mental trick to distinguish them, when looking at them in the barrel a right hand thread grows to the right (clockwise) and left handed spring grows to the left (anti-clockwise). Then I try not to think about it too much in case I break my mental trick and have to think of another way of remembering it. It's just like a normal thread you would see on a bolt, if you stood the bolt on its hex end and looked down it would have a right handed thread (well 99% of them anyway).
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
