I bought a hooted MSA02.004 and it is very very stiff and squeaky to use. To the point that it's tough to tighten around a stem and keep the stem centered.
Should I, can I lubricate it somehow to make it easier?
Edited by JeremyLaurenson
7 hours ago, Jon said:
A bit of grease on the thread that the collar goes over
Agreed, I just use regular lithium grease, not the stuff you use on your watches šŸ™‚
not trying to confuse here but there are different types of pin-vises, the one shown in particular looks to have square shoulders on the inside part that holds, if you tighten it too tight on the round part of the stem it could leave indentions that will wear the main-plate opening, especially on mechanical works, it is great to have for all kinds of stuff though, there is another type and maybe the opposite end of the one shown is this way, and that is that it has a round inside for holding round objects keeping it smooth and not maring the stem, the squeaking and tightness could be remedied by as said above and maybe un-screw end and look to see if any burrs or ruff surface is apparent, some of the new tools are not as refined/finished as the older tools......I hope this helps
    • Hi Mike I did a ships clock a long while ago, not a Hermle though and without getting the beast in my hands to refresh my memory I can’t recall the timing. Ā This doesn’t help I know but will start the grey matter turning.
    • I have stripped and cleaned a Hermle ships clock. It was just oily, no major faults, and I reassembled it, following my photos in reverse order. The time train is fine but the strike train will not play the ships bell strike for half-past. Ships bells play a four hour sequence for the 'watches' and play double 'ding' for the hour and the double dings plus one for the half past (eg half past the second hour is 'ding-ding' 'ding-ding' 'ding'). Sounds complicated but it isn't really. The strike wheel consists of pairs of bumps (for the ding-ding) and no single bumps. There must me some mechanism on the half-past that lifts the strike lever over one of the bumps so only one ding is played. When I get to a half past, it still plays double ding. I have a feeling it is to do with the lever in front of the rack (there is a sprung attachmentĀ  on it) and the position of the wheel (to the right) with the two pins that lets that lever fall, but no matter where I place that wheel I cannot get a single ding at half past! Please can someone help with advice on positioning so I can fix this? BTW Happy Easter 🐣
    • I think it would rather be the blast of high current drain that would do the damage. But if used occasionally to maybe fix a mainspring or do dial feet it might be worth trying especially if the mainspring or a replacement couldn’t be found.Ā  Ā  Tom
