Accutron not humming--components seem OK
1 hour ago, nevenbekriev said:
The short connections that You describe are possible, but it is not dangerous for the coils and even for the entire ciruit. The resistance of the coils is big, so the  battery voltage can not produce enough current to destroy anything. No normal multimeter can do any harm too.
You are right. It is not possible due to the huge resistance in watch coils (i measured about 2K-6K in mine). I confused the coils for being small L inductors, which usually have very tiny resistance.
@LittleWatchShop so maybe the culprit for the burnt watch coils is ESD via touch at the points mentioned? 600V of ESD should do it for 150mA into a 4Kohm coil.
8 hours ago, Neverenoughwatches said:
In my younger days tinkering with cars i had plenty of belts from petrol engine ignition systems running at tens of thousands of volts.
🤣 Yeah cars generate insane voltage, but the amps are low. I watch Electroboom sometimes to learn what not to do:
Edited by Zero
I doubt ESD would be able to destroy a coil.
The problem of open Accutron coils has always baffled me. Even if 1.55V were to be applied directly to the coil, it shouldn't be able to fuse the wire. And if anyone noticed, it's always the cell side coil that fails.
So is it a design fault that's causing that coil to burn? Maybe as the components age, the waveform changes and creates more back EMF?
Maybe @LittleWatchShop could investigate the cause of the failure and solve the mystery.
This coil has been failing since basically the beginning of time. Basically it's not a new phenomenon the prevailing theory way back when was that because jewelry stores and other people change batteries that's why that coil is the first to go out. So basically they were all gone a very long time ago way before any other component in the watch.
Somewhere but I don't remember where that I don't remember exactly why but there was a reference to the protective coating would cause a failure I'm guessing where the wire is soldered to whatever it's soldered to. So I suppose conceivably if the protective coating should change its size like shrink it could pull away and because the wire to break probably just about anywhere unfortunately.
Yes I agree, the coils doesn't burn at all, but the wire breaks due mechanical deformation of coil or another possible reason - the flux, used when soldering, has been not cleaned entirely and etches slowly the copper till it is broken.
But why does the etching prefer the cell side coil?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
