From time to time, one encounters strange "repairs" or "short-cuts";
Yesterday I opened a show case-back and noticed some white "plastic" in and around the movement 🤔
If the O-ring is broken or missing, why not using Teflon-tape ? 🤗 😁
  • Haha 2
Great stuff, PTFE tape (Plumbers Tape Fixes Everything) !
Problem with ptfe, generally in plumbing but it could be with any application of its use i guess, its supposed to seal the threads, which it does when there is no shoulder on a coupling.  But if a rubber ring such as a gasket is used or some kind of brass or fibre washer as with plumbing fittings then the tape can stop the joint pulling up tight. Its often wound on the wrong way and pulls away from the threads upon tightening. Shouldn't be used on the threads of olive compression fittings. Ha plumbing lesson
  • Confused 1
4 hours ago, Endeavor said:
From time to time, one encounters strange "repairs" or "short-cuts"…
Is this thread meant to be continued by others who found weird repair work?
Yes, please !
It may learn everybody some more about the "tricks" of the trade 😉
Here another one which annoys me since I haven't found an answer on how to fix it 🤨
I bought this gold-plated hunter pocket watch with a nice looking movement;
Only to find out, during my service, that the ratchet wheel screw wasn't only of the wrong size, but it had left-handed thread and to make it stick, kitchen aluminum foil was used.
The thread inside the arbor is totally ruined ..... 😡
No idea how to avoid this type of "scam".
Edited by Endeavor
  • Sad 1
47 minutes ago, rossjackson01 said:
What I can't understand with some of these 'botch merchants'' and I've met a few on my learning curve, is why they don't' use the correct  items. O rings are cheap enough
The problem is that there are plenty of people who for some reason are into repair without having any intent of doing a good job but instead just make a quick buck. They don't have the patience to measure, place the order, and wait for the delivery.
Could also be your well intentioned neighbor, who in his garden shed has a "go-at-it" and has no clue where to order or what to do 🫣
Plus plenty of people just don't understand the difference between quality work and a bodge job.  It doesn't matter how many good watch repair videos they watch or if someone tried to train them, they just can't see why it matters.
I made a few mistakes in my beginning. But I would never had offered the damaged watches to anyone. In fact I am now actively beginning the restoration of my own 'botched' work'. I have learned about the pride that servicing and repairing a watch can give.
Recently I serviced a Chronoswiss Kairos with an ETA 2892-2. This watch had a professional service 15 years ago.
During disassembly I noticed that the screws holding the automatic works were loose 😳
After cleaning and reassembling the movement I found that the automatic works only functioned with loose screws. Searching for the rootcause I found that the „intermediate reduction wheel“ in the automatic works was mounted in a flipped position. Relying on my foto documentation I had mounted it as wrong as it was before.
I successfully flipped the wheel back instead of loosening the screws as my predecessor did 😉
Edited by Kalanag
Does it show it correctly in the service sheet?
That's why I always take lots of pics. The first time I serviced my Breitling Aerospace I just couldn't get the bridge to sit on the gear train. I was following the service sheet. I double checked the pics to make sure the gears were the right way up - still couldn't fit it. Only when I looked at my disassembly pics did I notice that the service sheet is wrong, wheel 260 is shown the wrong way up.
  • Sad 2
