Elliott clock question
Rixy
I have been working on a 1960s/70s Elliott dual chime mantel clock. The case was poor but the movement seemed OK. I took it apart and cleaned all the wheels and the pivot holes (which were in good condition). It has a platform escapement which I did nothing to because it looked alright. When I reassembled it, the clock ran for a few hours then stopped. It got going again when I moved the hands but the most it has run for is about a day. I have taken it apart again to check I didn't bend a pivot by mistake but they look okay. Could it be the platform escapement? Not sure how to go about cleaning it and where to oil it. Does anyone have any advice?
Have attached photos of the platform if that helps.20240205_214805.thumb.jpg.22e928cdb2a9288c35b03a904c5becee.jpg20240205_214816.thumb.jpg.697062337bf333aa86f7d1a9a30c8802.jpg20240205_214845.thumb.jpg.f04a050031d731f6164d6f8a6a6d9c4b.jpg20240205_214905.thumb.jpg.a04ed16cebe8c79ec60d70a674dcba46.jpg20240205_214942.thumb.jpg.365bbae3d5cc41e7efd00621ad4a0f87.jpg
It sounds like the contrite wheel is not at the correct depth to the escape wheel. Make sure the teeth on the contrite wheel are good and make sure it has hardly any end shake. Cleaning and oiling the platform is needed, The screws that hold the platform to the movement gives you opportunity to also adjust depth.
Thanks for the advice and the instruction guide. To clean the platform will I need to get one-dip? Do I follow all the instructions about removing and cleaning jewels? For oiling, I have some Moebus pocket watch oil and a fine oiler. Do I oil the escape wheel teeth or the pallet jewels? Having never done this, I am a bit apprehensive about taking it apart.
If you don't have a watch cleaning machine. Clean all the parts with Ronsonol lighter fluid, after cleaning put the parts on some tissue and use your watch blower to dry the parts. If jewel caps can be removed then do so. Pocket watch oil fill be fine. Oil the pallet jewels and every other tooth on the escape wheel but do not over oil.
Rixy Elliott also fitted platforms that run silent just in case you don't like hearing clocks tick. Here is a photo of such a type, note the thick like hairspring fitted onto the escape wheel the escape wheel is different as well. My self I have some Elliott clocks 5 timepieces and 2 Westminster/ Whittington  chimes all with platforms
Edited by oldhippy
Thanks for your encouragement. I went for it. Reassembly was a tense moment but it's all together now and has been ticking since first wind and for over an hour - fingers crossed! This one isn't silent but very quiet.
The picture doesn't really show anything other than it being back together but thought I'd share it.20240207_214720.thumb.jpg.7c93322737d79267a372fffb7252f0af.jpg
These clocks are high quality, first class design and easy to work on. The only weakness I have found is with some platforms in the real older types they are not fully jeweled and you get wear in the pivot hole of the escape wheel. The really old Elliott movements are very dark in colour.
Good job Rixy. 😀
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
