Is this pivot broken
Hi all, I fell stupid for even asking this but does anyone think the top pivot is broken (the hairspring side). my eyes cannot quite make it out even with this magnification,  I serviced this watch 2 years ago and it has just come back to me , the owner said very rarely wore it just been sitting in a drawer takes it out a few times a year to wind it. last time he took it out it had stopped working. It was fully wound when returned to me and as soon as i slackened of the balance cock screw it started running, re tighten it stopped. literally half turn of the scvrew would start it running and in dial down position on the timegrapher it ran perfectly dial up terrible -897 and like it was magnetized so I assumed a broken or damaged pivot or dirt etc, when i took the balance off the cock as shown in the pics the first thing I see is a tiny piece of metal stuck to the underside prob 0.1 mm in length which I took to be the tip of the pivot but looking at the staff under the microscope I am not sure, what does anyone think. the watch is a vintage 1930s gruen curvex cal 440.
no that little bit of metal was stuck to the underside of the balance cock hence i assumed a broken pivot, you have confirmed what i really thought so i an thinking just dirt or congealed oil, the balance pivot was black on the end and i have now cleaned it and polishes it a bit, i have stripped the cock and cleaned the jewel and cap so will put back together and hope this solves the problem. thanks for the input.
no it still did not run properly even with the balance stripped and cleaned. It ran very slow on the amplitude almost stopping . I have now completely stripped it and cleaned it  and will start from scratch. I did notice that the mainspring seemed to be partly set so I have ordered a new one with my thinking being that the spring was not putting out enough power to move the balance as also if I touched the centre wheel it started the balance running properly. Fingers crossed that will be the answer.
One of the things that helps on these discussions is a name like we have above sometimes a picture is nice to see what were talking about
http://www.gruenwristwatches.com/440-movement.php
So we have a interesting background history. Also it's always nice if you show us the timing machine results so we can see what it actually looks like it helps for us trying to diagnose.
When you service the watch the first time did you change the mainspring? Because one of the problems with especially original spring is the blue steel ones they definitely have a habit of setting. Then unfortunately vintage old new stock mainsprings also have a habit of setting. With the added bonus now that the quality of some modern Springs isn't much better than the original Springs.
yes it was an vintage new old stock blue steel spring that I had in my stock, the new one that I have ordered from cousins appears to be a new one which as i type this has just turned up, also interestingly the size given on the Gruen website for the spring is different from the one in the GR catalogue (Gr2631 H 1.10 x T 0.11 x L 240 BD 8.5). I take your point about pictures I will endeavor to include them in future posts.
definitely set.
well the spring did not work, balance was still the same running intermittently and has now stopped altogether. Having a good look it is possible looks like the balance spring is slightly bent and is rubbing on the balance arm. Anyone know where I can get a new balance from for a 440 or 335 cal.
best i can do pic wise
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
