A very "newbie" to the hobby. I have disassembled a Waltham pocket watch (1908-610). In reassembling I reached a quandary. Failed to take a photo of the mainspring in the barrel (sorry, rookie mistake). Can anyone help me determine (with photos, that would be great), how the mainspring is inserted into the barrel. Also, what is the difference between a right and left hand winding. Thank you so much for your help.
I was going to ask for a photograph to see what were talking about but is this your watch or equivalent to it?
https://pocketwatchdatabase.com/search/result/waltham/26565067
Always helpful to give us a picture just in case we don't remember off the top of her head this model number and picture the mainspring barrel and puts left of the mainspring would be really helpful saves a lot of time of us having to look it up for you. Because often times people recognize the problems they may not recognize the exact model of your watch.
As usual by the way the pocket watch databases worthless for Waltham material and you have to go to a material  Book.
18 hours ago, dhall said:
mainspring
You didn't say what they are looking for a new mainspring I was still really give you the number any way and there's a problem ideally you should use a vintage mainspring or an original mainspring as opposed to modern mainspring because you going to have issues with that
then because yours is a seven jewel watch if you had a choice should go with the heaviest mainspring possible. Except typically today are only going to have a choice modern Springs you only have one spring you don't get a choice and modern Springs have issues unfortunately
If You are asking in which direction to wind the spring in the barrel, then place the barrel arbour in the barrel (in the correct way) and look at the hook on the arbour. It will show You the direction of the spring. If it happens to wind the spring in the wrong direction, then rotating the arbour in winding direction will lead not to winding, but to deforming the internal end.
This arbor is fixed in the barrel top. The hook is pointing in the clockwise direction. In the barrel itself the hook is also pointed in the clockwise direction. Pictured below is the new spring I just obtained. Looking at the spring orientation that is pictured, am I looking at it from the barrel top's orientation or the barrel's? I know this question is a bit silly, but I just have a mental block understanding the right orientation.  Thanks for your patience with this newbie issue.
I have inverted the image of the spring in the container. You must insert it in the barrel the same way as I have oriented it in the container. IMG_20240220.thumb.jpg.7e8eb4eb124cdd959695c59c4c2587bd.jpg
Edited by nevenbekriev
Richard, Thanks for the kind guidance.  Now that I know how the spring is oriented, it makes all the sense in the world.
Thanks again,
Don
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
