Hey folks!
I was in the radiology department when the X-Ray machine needed to make some test-scans for routine calibration. The technician jokingly asked if I had something I wanted an X-Ray of ... so naturally I handed him my watch. Can you guess the watch I wore by the scan?
On 2/9/2024 at 8:19 AM, CHRGDR said:
X-Ray machine
In addition to x-rays does the machine have a byproduct of magnetic fields? Yes I know a better test for your watch would be with the MRI machine but what sort of magnetic fields does the x-ray machine produce and did it affect the timekeeping of the watch?
As far as I know an x-ray machine does not produce a significant magnetic field nor is it influenced by one. I am no expert on this matter however, so I might be wrong. I have not noticed any negative effects on timekeeping yet. I probably would not have done this with any of my older, more delicate watches though.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
