Accutron missing dial feet--proposed solution
Background:  Somebody sent me an "Accutron" that was a gift many years ago.  Somewhere along the way, the Accutron died and somebody replaced it with an NH35.  It, of course was too thick, so they removed the auto wind oscillating weight. Ouch!!!  Since the dial feet did not match, they cut them off the Accutron dial and used sticky tabs to attach the dial to the NH35.  What a frigging abomination!!!!
Anyway, this "somebody" sent me two accutron movements in hopes that I could return the watch to its former glory.  OMG, these were hacked up as well.  But!!! I was able to make one functioning movement.  Cleaned, oiled, and soon to be adjusted.
The BIG issue now is the dial.  I am pretty sure I cannot solder feet on the dial.  I did give it a try.  No bueno.
Here is my idea.  Drill holes through the dial where the dial feet belong.  Then insert and glue posts (feet).  I checked the visibility of the dial through the crystal and the drill holes would not be visible.
Thoughts??
Edited by LittleWatchShop
16 minutes ago, RichardHarris123 said:
How much is hidden on the face side of the dial. Could you form a head, like a nail, on the feet to give more surface area for the glue?
It would be close.  But these Accutron dials are relatively thick.  I think there would be enough surface area to make a good bond.
I went for it. Turned these feet on the lathe
1 hour ago, eccentric59 said:
dial foot repair tools
I have one of these.  However, the Accutron dial makes an abrupt curve near the edge where the foot goes.  This tool/feet would not work.  I could have opted not to drill all the way through the dial.  If I had a visibility issue, I would have done that.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
