Hi have you tried watchfanuk on eBay Gleave and co,   HW Walsh ,  Cousins uk,  Esslingers. Otto Frie,  Tinesavers,   In the U
s.      A G Thomas in the uk. Not knowing your location I can’t be too specific but a few to look at.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
