Auto-oilers have a place, as said there are different tips and types, I remember the Obama oiler that had different settings, they are expensive for the nice ones, don't have any cheap ones to compare, for beginners your method will work just fine and save time and money ....
On 2/16/2024 at 1:32 AM, Birbdad said:
Personally i find setting and oiling balance jewels wet really easy. I just do those the old fashioned way. I tried it with my auto oiler and it was pretty awful.
Same here, and I do that whenever possible. The problem is when it's not, like on pressed-in Accutron train jewels, or a handful of settings I've come across that are not meant to be disassembled.
On 2/16/2024 at 11:32 AM, Birbdad said:
I"m proud to say that i can set them in seconds now my tweezer skills have improved so much.
That's really fantastic as most of us seem to struggle with them. This video clip really impresses me. Congrats!
BTW, are we talking about the rectangular Diafix springs or the tuning fork style Diafix springs? It's the rectangular ones that I find extremely "feisty".
In another thread somewhere here i drew a diagram of how i set them and it works super well.
That would be interesting to see. I visited your profile but was unable to find it. If it's not too much trouble can you link to that post? Thanks!
BTW, here's an interesting thread about those rectangular Diafix springs:
I am indeed talking about those godforsaken diafix springs and here's the step by step of how i do it now. It makes it basically impossible for them to ping off because they're trapped by two points before you even really try to move them much at all.
On 2/16/2024 at 3:00 PM, Nucejoe said:
 Birbdad,
Gosh, Poor dog , for your steady supply must grow new whiskers in a hurry.  😷 🤣
Try acupuncture needles instead.
No need, I just keep the one whisker in a safe place! 🙂  At the time I had no supply of acupuncture needles, and the dog whisker was readily available.
That sounds like a good idea though.
Edited by steve855
On 2/16/2024 at 2:00 PM, Nucejoe said:
 Birbdad,
Oh...accupuncture needles?! That works?
I think they're too big Col, the smallest i could find when i bought mine 18 months ago were 0.18mm.
yeah I sorta figured as much. The needle on the auto oiler is so small and so fragile if acupuncture needles were that small i'd think they'de be breaking off in people left and right.
You could always thin the very end down. I think the idea of a cat or dog whisker sounds great, how about a paint brush bristle ?
4 hours ago, Nucejoe said:
 How about thinning whiskers on lathe ?
I  hope bergeon doesn't read this , hate to see whiskerless dog community.
Its one whisker Joe not a whole muzzel of them 😅. And yeah i hope Bergeon do read this 🤣
I think I tried a paint brush bristle but couldn't find one in a small enough diameter.  Seems like they're bound into the brush,then trimmed evenly to length.
My dog whisker is tapered right down to infinity! The taper makes it easier to manuever also.
Does anyone have the diameter of the A1 oiler needle tip? I found one site which has 0.25mm, but doesn't look like a reputable site.
Screenshot_20240220_131543_SamsungInternet.thumb.jpg.91d2c1626abc74220d69c3bb1bcdab94.jpg
According to Esslinger, the 1A has a tip of just 0.1mm.
I bought a China copy from AliExpress and the tip was a sharpened point, like a pencil. I didn't examine it carefully, it might have had a pivot like point which broke off in transport.
Anyway, I sharpened the tip to a needle point and it works.
I've used 0.1 mm copper wire. It's commonly sold for circuit board repair, in small quantities for just a few dollars. Grab a bit with some tweezers. It's a bit small to hold on a pin vice.
It's soft, so less chance of chipping the jewel. And you can bend it when something straight can't get access or would block your view.
I'll have to try that. Replacing those rectangular Diafix springs has probably been the most difficult motorically among all the challenges I've taken on since I started.
Clever to take advantage of the spring not only springing in one plane but also springing when rotated in opposite directions. I probably never would have figured that out on my own.
BTW, if anyone wonders about the origin of the Diafix name it stems from the word diabolic. The Diafix spring was invented by a particularly sadistic Seiko employee who, during World War II, worked on the design of exceptionally painful torture methods 😉
That's massive. Don't know the diameter of these jewel holes but definitely < 0.10mm. Perhaps the diameter can be reduced using sandpaper.
I have the 1A oiler and I think that 0.1mm is correct. For those considering getting this oiler be aware that there are capped jewel holes that are smaller than 0.1mm. At least one of the two jewel holes on the Seiko 7sXX train wheel bridge is smaller than 0.1mm if I remember correctly.
Edited by VWatchie
Yeah, the diafix springs were torture, to the point i would just put off servicing a watch cuz i knew i'd probably have to set them a few times. It's sooo nice being able to just do it in seconds now. Practice that method and it gets easy quick!
Also my 1a oiler does appear to fit every jewel hole in a 7s26. the escape wheel is iirc the smallest hole and it just barely fits in it.
OK, so I didn't remember that right, thanks. It was probably some other movement. Nevertheless, I prefer my Incabloc oiler.
Currently scheming to come up with a better solution than the wheel i use that's cheaper than an inkabloc oiler. I would like something longer so i can see as i do the oiling just how much is making it's way into the setting.
I have a question, as i do a lot of old swiss watches that have non shock fixed balance jewels. To oil these ofren the hairspring is removed from the balance to get to the fixing screws from underneath which is a little time consuming especially if the hairspring is unpinned. Without this though there is no real way of knowing how clean inbetween the cap and balance jewel is. Does this apply to the jewels you are oiling here ? Not the most ideal cleaning operation can leave residue inside.
There is no other way than to unpin the hairspring and remove the balance wheel to access the two screws and remove the capstone.
Reassembling the capstone, regulator arm and balance cock without smearing the drop of oil can be challenging at times. Ever since I got my auto oiler, I reassemble the balance assembly and oil through the jewel hole.
It is almost impossible to over-oil the capstone this way as any excess oil would remain on top of the jewel hole. I then dab off any excess oil with a root canal paper point.
I always disassemble this way hector, only sure way of knowing the capstone is clean. I was curious to know if people were disassembling these tiny seiko cap jewels to clean them first before oiling them from the backside
Yes, that is what needs to be done, but some don't and leave them in claiming that all you need is efficient cleaning fluids. I highly doubt it though.
This thread just saved me $. I was just about to buy one of those oilers.  Thank you guys.
I’ve been using a very fine beading needle honed to a fine point and it works pretty well. I guess I’ll just stick with that.
Edited by BillM
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
