I  have a chipped K&D center set punch with my staking tool set and was wondering if there are any companies providing professional sharpening/refinishing for watchmakers?  Are they any ways to do this at home?
Unfortunately, I do not own a lathe and am a little hesitant strapping the punch to my power drill.  Any advice?
Thanks,
Dan
Thanks,
Dan
If it’s the punch used to centre the table I would think that would have to be done on a lathe.
Tom
5 hours ago, rossjackson01 said:
This video deals with the way to repair a jewelling set. Should work for a Staking set. At least you can compare and modify to suit.
https://www.youtube.com/watch?v=KS1G5-SmjaQ
I like Alex's videos but in this instance I would need to use a lathe or rotary drill.  The punch is used to center the table on the staking tool.
Tom
Yes, it's THAT punch.  I would like to have it as close to perfect as possible.  Any watchmakers or companies offering this service?
Edited by menez718
The King of punches 😂
…just wondering - how many staking sets do you have? Just one?
Edited by rehajm
Just the one set I purchased from Goodwill.  The center set punch it came with appeared to have been sharpened (poorly) but does the job.  I picked up a used punch off eBay with a chipped point.  I now have two punches to be refinished! 😂  This damn hobby makes a tool junkie out of the best of us!
I've done this with a tool and cutter grinder. It is important that the centre be axial with the punch.  Most small engineering shops would have one so maybe finding a friendly local one might be a way forward?  Punches are often non-standard sizes so it probably needs one that has collets to hold the work.
