Came across this Robur-ish press on ali,  it's descibed as high quality rotating open watch cover but looks to me more like a watch case back and crystal press similar to the Robur screw down press or am i wrong and the description is correct.
This could be a good buy if it is a screwdown crystal/back press, but what are tools that are with press in the photo.
https://www.aliexpress.com/item/1005006537025267.html?spm=a2g0o.cart.0.0.479c38dacW6CTc&mp=1
Edited by valleyguy
Thanks Tom, that makes sense how you describe it.
I wonder if that upper tool bit is just push fit into the centre shaft so could be removed to take a robur die or an m6 die adapter and double up as crystal press.
I'd love to see what size hole is under the white plastic adapter on the bottom base plate.
Just wishful thinking of a poormans robur style press.
I
Looking at the listing there is a second upper tool and lower piece too and they look push fit. No info on the spigot size but I think they are likely smaller than 6mm.
Tom
Just looking at the picture I thought that looks cheap and nasty. Then I clicked on the link and I was right.
I had the proper Robur press and they are OK but not that good. I had many glass fitting tools that were far better.
On 3/2/2024 at 3:11 PM, tomh207 said:
@valleyguy this is worth a look for a Robur type press
Tom
Thanks Tom, i ordered the same press last week, it came today, seven days delivery from China to the UK on ali using choice.
The fit and finish is perfect, no maunfacturing defects or cosmetic damage i can see, they must have quality control in place, it came well packed in a polystyrene box, i tested it with the dies that came with it and the cousins aluminium dies (6mm thread) it closes perfectly square, the spindle operates smoothly up and down, for the price it's an excellent buy.
If i'd got this first i don't think i'd have got the Bergeon 5500 lever press, i won't need another press between the two i think i'm covered.
If your wanting a decent press at reasonble price the E25 (Bergeon 5601 clone gets a MASSIVE THUMBS UP.
This is the one i went for:
https://www.aliexpress.com/item/4000481398244.html?spm=a2g0o.productlist.main.1.e2adlm8Alm8AYe&algo_pvid=767bb68e-0c8e-415a-a6c3-5c9d5471f34f&algo_exp_id=767bb68e-0c8e-415a-a6c3-5c9d5471f34f-0&pdp_npi=4%40dis!GBP!39.73!32.41!!!48.84!39.84!%40210387a117095660343244016e9259!10000001996262784!sea!UK!0!AB&curPageLogUid=NPF60yvW9VHm&utparam-url=scene%3Asearch|query_from%3A
  • 10 months later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
