Basic question on Bergeon MS winders
ooteenie
I am about 15 months into watch repair/cleaning and have handled a number of movements over that time. Largely vintage mens watches with AS, FHF, and some ETA movements but also some ladies movements as well. As this point I largely hand wind springs, but in some cases I fit new ones if needed.
I don't want to spend money on a cheap set of winders, and buying a vintage set could result in a great deal or great misery depending on the shape of the hooks on the arbors and then dealing with the return on Ebay which would be a pain. For that reason, I am compelled to shell out for a Bergeon set or individual winders. I have never seen nor held a Bergeon winder in person, but I understand how they work and the sizing options.
My main question is around the arbors.  Barrel arbors in many  watches I work on are similar size, not exactly the same but similar. This seems to be independent of the barrel size where a 7mm barrel may have an arbor close in size to that in the 9mm barrel. How are the Bergeon winding arbors sized? I get that these are used by a great many people, but before I purchase I am curious how snug the mainsprings fit to the arbor/hook when using the appropriate sized drum for the barrel. Does the process require fiddling or is it fairly straight forward get the hook set in the spring?
Ultimately getting the winding started is, from what I expect at least, 80% of the challenge, the remainder is making sure you don't open it slightly while winding causing the spring to blast out.
Here is a chart showing the sizes of the arbors and the external diameter of the drum for the various sizes. There are times when for an appropriately sized drum the arbor is not the right fit so then I would try using a bigger/smaller sized arbor from one of the other winders. Usually that works but there have been some where I couldn't find an arbor that would work (eg, Omega 8900). You can supplement any Bergeon winders you purchase with one of the cheap sets on Aliexpress, which is what I have done.
1 hour ago, mikepilk said:
I have a small set of winders, not Bergeon. I most often use the 10.8mm, but often the arbor is too big for the spring.  I have a small length of brass tubing which pushes in to the winder base, and allows a good fit of the next smaller arbor.
that is clever for sure
@GuyMontag Thank you for the list, looks like redundancy in adjacent sizes. I have thought of one of the cheaper sets, and maybe that would work in some cases, the challenge with them seems to be that they are based on movements rather than strict sizing. I did find one that had decent arbors that were steel vs the inexcusable use of brass, but I think the Bergeon ones are a better long term solution and they will still retain their value.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
