Hello!
My late father left me this clock (by the pictures, it appears to be a Junghans Wurttemberg from 1932).
If I remove the back plate, I can tease the movement to tick for a few seconds, but then it stops. I would very much like to have this beauty back in working order (I believe the disk at the top of the second photo actually strikes the top of enclosure as part of the alarm).
I live in coastal North Carolina and am searching for a reputable repair shop to send it to (the only one in my area said that it'd be 3-5 months before they even could take a look at it).
Please reply here with your comments - or to me personally at *****@*****.tld with suggestions about next steps. Thank you.
image.thumb.png.c82cd28c27823986de2dd220e10ed35f.png  image.thumb.png.09dab1257637073d1fca49144dc7e38a.png
Hi what is it you want to do ? Find a repair agent or have a look yourself.  If it is the latter you need to remove the movement from the case then remove the hands and dial leaving the bare movement.  The cheap and easy way is to clean the clock as is with paraffin or petrol and leave to dry. After first removing the power of the mainspring .  Then oil with light machine oil and give it a run.  Alternatively it will need dismantling and cleaning, re assembling and lubricating either by yourself or a professional, it’s a choice only you can make. If you choose the latter we the members will be here to help.
I believe that movement has an alarm feature, most of the clock guys I know are backed up for a while, I know a young man [and grandfather] that might could help if you don't want to tackle it yourself, his name is Grant Wood, he lives in Advance, NC not far from me, we both belong to NAWCC and the Golden Triad Watchmakers Guild ....
Carolina Clock Repair
Have a clock that you want to get working again? Maybe you just need regular service for your Grandfather, mantle or wall clock. We offer house calls for GF clocks as well as pick up and delivery of mantle/wall clocks. Schedule a service with us to keep your clocks in running condition!
For Grandfather clocks Call 336-692-4366
For mantle or wall clocks Call 336-251-3655
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
