It's an Omega Speedmaster Broad arrow.  The broad arrow refers to the hands, being wide.  The hands on yours seem incorrect
Are you sure it's genuine?
thats the thing,im not sure i did some research and the hands are wrong so i have no clue,ill have to take it to an omega store to have it checked out
 Hi omega broad arrow.  The fact that the hands do not match the picture supplied by Richard is suspicious. Mikepilk suggests removing the back, that’s the only way we will  get to find out what ticks inside genuine omega or substitute movement.
Does it run?
Watch accuracy meter app is online and free to download.
Next, Put your watch on mic of your phone, lets the watch stabalize for  few minutes, then  hit the start button, do this in at least 3 positions, show us the graph, I can  tell you if the escapement is good enough to be Omega.
PS: I am getting good at it. 🤠
Edited by Nucejoe
12 minutes ago, Nucejoe said:
Does it run?
That's amazing. I didn't know an app could work using the phone mic. Just downloaded it and tried it on the watch I'm currently regulating. It agrees exactly with my Weishi 1000.
It would be a pity if that watch would be a fake. I love the design and I just finished servicing my 1975 Mark II; original hands, but they are re-painted & re-lumed.
Edited by Endeavor
@Endeavor  let us see graphical display in 3 main positions.
Adjusting costs more than a fake watch.
Takes a master watchmaker two weeks to adjust, I am looking to buy a Grand Seiko, says 17days to adjust it.
Rgds
10 minutes ago, mikepilk said:
Agreed, but it did a decent job :
Yes you did. whats the watch ?
32 minutes ago, Nucejoe said:
whats the watch ?
It's the Longines 30L I posted about in "Longines Balance staff pivots - are they too flat ?"
I wanted an accurate wristwatch, and I'm not disappointed. I wore it  all yesterday, including playing a round of golf - it's a good tough test for a watch. After 24h it was -1s.  So I tweaked it 🤣 a bit to what you see +1 to +2s/day.  If you want an accurate watch, I recommend one. (It was @nickelsilver who suggested the 30mm Longines as being accurate).
BTW I remember seeing a video about a Patek Philippe tourbillon - they take two weeks to adjust it.  £££
 Ya I remember, you didn't say  anything about poising the balance,  I guess you didn't , so I  gathered you must have mastered fitting in staffs.  Thats really something.
There use to be staff fitters in my neck of the woods, thats all the guy  did all day so got real good at it, hardly ever a restaffed balance needed poising.
Congrats, good results, enjoy your watch in good health.
Can't you remove the back? A cheap tool will do if your not taking watch repair up as a hobby.  Or use the nut method, glue a nut to the back, unscrew, then soak the back in acetone.  Polish the back.
Either way, let us know the findings.
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
