Wonder if someone has done this movement before? And if there is any walk trough help somewhere? Am a little scared of doing wrong . This is kind of rare movement i think ? This are some pictures of the keyless work and that side of the movement . Lot of springs and lefthanded screws . The big black screw is lefthand tread .Two screw marked with arrows are left handed !
post-644-0-87949800-1442933956_thumb.jpgpost-644-0-75375000-1442933950_thumb.jpgpost-644-0-66507900-1442933944_thumb.jpgpost-644-0-80511900-1442933937_thumb.jpgpost-644-0-91401100-1442934550_thumb.jpgpost-644-0-84660900-1442933925_thumb.jpgpost-644-0-79751300-1442933918_thumb.jpgpost-644-0-24147300-1442933903_thumb.jpgpost-644-0-25056300-1442933895_thumb.jpg
Is the black background better? Looks like the details are easier to see?
This part can't be removed until i remove parts from the other side of the movement .
Edited by rogart63
Worked nice for me to remove it . Couldn't see any threadlock. But is a lefthand thread . Used a little larger screwdriver of course .
Now on  the other side. Lifting the whole automatic mechanism off . In one piece . Will deal with that later .post-644-0-30224900-1443005470_thumb.jpgpost-644-0-83885800-1443005477_thumb.jpgpost-644-0-93441000-1443005485_thumb.jpg
The top clasp is for removing the part on the other side i could remove until .It's for releasing the stem from the keylesswork . post-644-0-71638800-1443005491_thumb.jpgpost-644-0-37182000-1443005498_thumb.jpg
click spring for removing spring tension in mainspring . And one of the wheels can't be removed. Will be cleaned and just lubricate later .
Not your ordinary barrel arbor .
Started with assembling the keyless work .
That's it for today .More tomorrow
Edited by rogart63
Has cleaned the barrel and mainspring . Now i will assemble that . But first i have take apart the upper bridge with the reverse wheels . I wonder what kind of oil i should use to oil the reverse wheels? D-5 ?
post-644-0-04391400-1443095426_thumb.jpgpost-644-0-92149400-1443095440_thumb.jpgpost-644-0-57931600-1443095447_thumb.jpgpost-644-0-85201000-1443095461_thumb.jpg
Coming together again . As you see the barrel has a slot in the arbor . That is for winding up the mainspring post-644-0-98425000-1443105068_thumb.jpg
Edited by rogart63
Went a little fast there in the end . Parashock jewels in the balance . Same as in a Seiko movement . They are easy to work on . As long as the spiral is in one-piece . As you see i have removed the rotor. Much easier to put things back without the rotor swinging around . Have a few things to put back on the dial side . Like the date ring and two springs for the winding mechanism .
post-644-0-07020300-1443193183_thumb.jpgpost-644-0-12940400-1443193177_thumb.jpgpost-644-0-33955400-1443193406_thumb.jpg
Haven't got the winding mechanism to work properly . Now i understand :).Thanks to all the pictures i have i can see that i am missing a little bushing . It's where i point with the black arrow.  Have looked on the floor and on the bench. Have not find it :( .
Edited by rogart63
Yes i found it .That must be one of the smallest thing i ever found? I don't now when i lost it?  The room has been vacuum cleaned everyday .Thanks to my little tape roller from Ikea i found it :wub: . Love those tape rollers :) Now it's working great .
Edited by rogart63
HATE  pallet forks . One of the jewels on the pallet fork was bent down. Manage to straighten it but the movement ain't working so good . Have some pallet forks from a citizen 8200 movement .Looks the same but don't now if they would work . There is nowhere i could check either?
Nope the pallet fork for the 8200 is not the same as for the 5420 . But the fork work like it should? There is no speed in the movement? Very low amplitud? The mainspring looked ok . Nice S-bend . Have now idea where to find parts for this movement? New mainspring? But what size? Nothing on  http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Citizen_5420 about mainspring size?
Edited by rogart63
Snapped the 4th wheel pivot  :pulling-hair-out: . That is why i haven't updated . Change the mainspring and it works ok . But when i should put everything back together . Snap  :growl:
Edited by rogart63
What a great post you've presented . It's like watching a soap opera...only better . I have serviced a few Homers and 8200 calibers , but this caliber is new to me .
I can suggest that you talk to Sweephand [stephen} as he has the great Vintage Citizen blog . He's a really good guy and the guru of vintage Citizens . He's always my go-to guy for Citizen questions .
http://sweep-hand.org/
That's a bugger Roger, it was all going so well. :( Are spares easy to obtain?
I manage to find some parts from Oldswisswatches.com. Also found two movement on Ebay . But they where very rusty . So avoid if i can . Hope this would do it . Had put the movement together but did'nt find any amplitud . That why i tested on changing the mainspring .
I've been looking around....Ranfft puts the 5420 in the 54xx family [kinda] , and I was looking at Sweephands Citizen movement table from the 30's to the 70's...
and saw 5400 movements from the 60's and early 70's listed and related .
Also I saw these donors for sale on the Bay...5430 , 5440 , 5450 , and 5470...
There were more donors listed but I only attached this example .
Sweephand could probably tell you more about interchangeability on this movement family .
I wanna see your watch running .
They will all work .As long as there in the 5400-5470 family . I have those and some other movement in my watch list . My thought was that they where to rusty to find any parts from .
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
