Silly question about chime replacement
Nvoss
Apologies in advance if this is a ridiculous question. I know very little about clocks.
As I was growing up, my grandparents had a mantel clock with a Westminster chime which I always loved; now, sadly, it's lost to the ether. I received a different mechanical mantel clock as a gift many years later. From what I can tell, it's likely German, looks to be 1930s based on style, but exact maker is unclear to me. I don't think it's anything special, but it's attractive. I like its chime, but it's a simple single chime at :30 and the number chime on the hour.
Is it possible to swap a basic, single chime like what this clock has for a Westminster chime? I understand the Westminster chime must have a totally different apparatus, since it hits more than one note, but I have no idea if this is possible to do, or if it's possible for someone like me with no experience to do through careful internet study.
I agree with Nevenbekriev. What you currently have is a striking clock, not a chiming clock. Not only would the whole movement need to be changed, the dial would need to fit exactly in the front hole and you would need to take out the gong (am guessing it is a coil on a stand) and fit a set of chime rods. There is also the risk that the pendulum on the replacement movement would not have enough room.
If your clock is in good order, enjoy it for what it is. If you still want a Westminster chimes clock, you can get them on Ebay - you might get a bargain.
All has been said I totally agree with both. You can get a good Westminster chime for under £50. If you want a high grade one like an Elliott then you are talking over £200, if you can get a Smiths chime parts are available and normally many on ebay.
Nvoss no question on here is silly.
Edited by oldhippy
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
