Diagnosing an unopened watch... (Rolex 2135)
Knebo
12 hours ago, JohnR725 said:
12 hours ago, Knebo said:
210-220 (this is after 20h of running perfectly fine).
the amplitude would be fine as long as you're in the right position the image you showed way up above look like it was dial down that is not the right position
This was in a vertical position. Like in the short gif video. Amplitude is fine across all positions, at full wind and after 24h. I could post tons of pictures, but please take my word for it.
On 2/21/2024 at 8:49 PM, Knebo said:
my friend may return it to the seller if I can't fix it.
this is a interesting remark? In other words your friend is buying a defective watch and hoping you will fix it? So why exactly is the watch being sold in what condition is it being advertised in? One of the problems with Rolex and other high-end watches is people often times past their problems on to unsuspecting buyers. There is a series a Rolex watches where the base caliber  runs at one frequency but the others run at different frequencies and often times we get these watches with awed timing stuff because someone did a mixing and matching of components to make a watch and then pass it off as it has a minor issue. So where is buying this should get some sort a guarantee that the watch is actually an perfect running condition which it's not if you're looking at it as somebody may be just passing problems on to the next person which is why you're having a problem
It was advertised as running fine and my friend was surprised that it didn't. The seller has a very good reputation on Chrono24, so I doubt that it's an intentional pass-on of problems. He responded quickly offering to take it back (and paying for all shipping) or reimburse 300Eur for a local service.
If the problem is what I/we think it is, then the latter is a good offer for ~1h of work and a 50-100 Eur spare part.
UPDATE: so finally, it stops every 12h. Always somewhere between 3 and 3.30. Not a precise time.
Shaking it a bit, will get it running again.
Edited by Knebo
Given that it's repeatable every 12 hours I'd look at the hour wheel or hour hand. It could be a bent or dirty tooth on the wheel, or the hand is touching the date window enough to stop it. Until you get it open, you can't be sure.
6 hours ago, Knebo said:
I'll update you as soon as a final decision has been made by my friend (and depending on her decision, what I may find inside).
I have a minor confusion here? The choices were send it back and get all your money back or get some money and have it fixed? Then the wording of the original title was we do diagnostics by crystal ball of not opening the watch up but now you're going to open up the watch to investigate?
No no, your initial understanding is correct.
I've advised my friend on the situation: possibly an easy fix, maybe a bigger issue.
IF she decides to keep it and take the partial reimbursement THEN I'll open it and let you all know.
1 minute ago, Bonefixer said:
Two worn teeth in the SE position?
Is that the hour wheel?
Yes and yes 🙂
Quite astonishing that this damage would stop the watch completely. It's possible, though, that there was some of the debris also stuck.
Hello all,
just to give you a final conclusion to this topic:
I got myself a new hour wheel and changed it without servicing the whole watch. Unfortunately, this problem persisted and I assumed that maybe some debris from the damaged hour wheel continued to cause issues.
So I did a full service.
Now it runs perfectly. Quite impressively actually: average of 0sec/day across 5 positions at full wind AND after 24h -- with a delta of only 4seconds).
Thanks everyone for helping me pinpoint the problem. My friend is very happy now.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
