I spent some of my spare time, this last weeks, to set up a logbook system that fits me, helps me to follow my progress and my stocks and more.
I also started a "Tableau de casse", a word game in french like hall of fame/shame, literally a table of broken 😁
One diafix on a Seiko Lord Matic :
I spent time with this diafix to remove the jewel, and when  it was time to put it back, the diafix was blocked. I tried to move it forward without success. Backwards, sideways, then I forced it a little (too much)...
I found some spare in china.
Extracting a scratched glass on a Seiko Lord Matic Deluxe (buying the right dies will help):
First sprint put back in its barrel (almost, except one part...):
From this broken one. The first time it's difficult to hold the winder and push the end through lunge... I hope I'll do better the next time!
And you, how do you manage your evolution ?
Edited by nico
I haven't been keeping a written log or hall of shame, but I can tell you that my early attempts to unwind mainsprings have resulted in two barrel arbors entering the ionosphere. Still MIA. I've launched but subsequently found incabloc and trior springs, a few yoke springs, and a third barrel arbor, but those first two remain elusive. (and one was from a ST36... not a small piece of metal, really)
I'll don't take in account the 3 or 4 little springs that flew away and the same amount of hours I spent to find them 😁
Now I work under a bag in which I cut a slit when I have bad feelings with springs and I work like a surgeon 👨‍⚕️.
As I'm not sure the translation is correct, so to illustrate my current approach I took this picture. Of course I use a little transparent bag
Edited by nico
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
