I'm working on a Waldan and have one step to go with disassembly and need some advice with some issues. First, the cannon pinion slipped right off, no resistance at all. I read that ETA movements can be attached to a wheel,  which mine is, but it doesn't look like the same kind of wheel with two bars. Am I supposed to take off the wheel, and if so how?
Second, I can't remove the stem. The setting lever screw is loose, but I still can't remove the stem and I don't want to yank on it. Of course, the setting lever is problematic for removal. Also, the screw above the clutch wheel, shown, won't budge. I think it holds the center wheel bridge, but not sure. I tried oil, but no luck. Thanks for your help.
I was working with this movement just today... The center wheel doesn't come off.  The technical docs show the main plate comes with the wheel attached, and there is no part number for it. Mine had a normal canon pinion over it, it was not attached to a wheel.
As for the stem... try removing the setting lever screw all the way and removing the setting lever.  The stem should retract then.
This is Riskopf type movement, complitelly different from what considered as 'normal' movements. They don't have center wheels at all. What You see there in the center is actually the center seconds wheel, and if removed, the movement will be able to work normally without it. The cannon pinion here does not have 'clutch function' for hands setting and it should go on it's post without resistance. The 'clutch' that alows hands setting is located on the main spring barrel.
No reason to have dificulties with stem removal. Untighten the setting lever screw more, and if needed - press on it's head to make the setting lever move down in order to release the stem.
Thanks for your advice. I got the setting lever screw off just by twisting more. I won't try to remove the pin that holds the "cannon" pinion. The keyless works bridge screw is frozen solid. It may have rusted inside. I'll clean and reassemble from here. Yes, this Roskopf movement is a strange movement, or different. It's good to know the name. Here's an interesting history. https://www.timewornwatches.co.uk/guides/roskopf-movements/
Waldan has a fascinating history as well. He made some unusual watches.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
