So today I received the set of spare Landeron movements I had bought last week. I received some spares, and 4 incomplete movements, various models, and a dial.
Movements are completely dirty, will definitively need a good clean on my Elma, and the dial has also some patina, which actually I like.
Here the pics:
A very fast clean (by no means to make it working perfectly) and I put some parts together with  the best looking movement, to have a working watch.
I do not have proper cases for the chronographs as of yet, but I am still looking. Here my 3 chronos:
The Walker and the Bovet are Landeron based, while the Gigandet is a Valjoux 7733
Sorry for the low quality pics, my mobile phone is just too bad...
Today I dedicated a couple of hours to the lot of landeron movements. I managed to build one complete working movement up to now, but to do this I had to use pieces from the other movements. I believe I can still build another complete one with some over spares I have, but need to check.
Atta Boy , You're on a roll ~~~~~~~
I took some pics of the movement once assembled. Please note the movement was not duly serviceed but only roughly cleaned just to remove the old oil and grease and put together to see if I could make a complete movement, so it is stained, full of scratches and not really in the best condition, but oiled as it should be. If only I could figure out to upload from my cell phone...
And here's finally a couple of pics of the movement assembled (sorry for the extreme bad quality, my mobile phone is not the best one to make such detailed pictures...):
Accuracy and timing are not tested yet, I am sparing some money to buy a proper timegrapher... but at least it works... 1 of four... Now on to the  next one!
Edited by GeorgeClarkson
Fine work on a beautiful movement! I think it was worth while to get it done from 4!
( This movement is very similar to the VALJOUX 7733, older but although more "aesthetic", isn't it?)
Actually I would talk about a "sibling" movement: there are a lot of similarities, like with other chrohographs.... but the differences are not only aesthic, but both movements are not so far apart either...
Should I chose one, I'd opt for the Landeron, since it is more decorated and decorative. Else I like them both, really.
Luck has been looking the other way lately... on of the pivots of the coupling clutch gear broke inside the lower jewel while I was testing the movement, apparently it was already damaged and my testing gave the final blow.
Now I need a complete coupling clutch (part 8080) or just a new gear. Problem is, I cannot correctly identify the Landeron model no. this clutch belongs to, since the design is somewhat different from the models I can find reference of (and Ranfft is of no help, since he is using the same picture for several Landeron movements...)
Since of the spares I bought only 2 had the clutch, and one is already mounted and the one that broke is the second one, I am out on the search for a new part... wish me luck!
And finally the Walker Landeron 248 movement has found a new home... I found a NOW Landeron 248 case on eBay, and jumped on the occasion. This is the still not final status, since some things need still to be done, but it is finally a complete watch!
Sorry for the bad pics, as usual.... Here the watch in all its glory with a leather band that was sent as gift from the seller of the case (that was nice indeed)
Things still to do: replace the glass since it is badly scratched (and it did not come with the case but with another movement) and the crown/stem, that apart from being well used, the stem is a bit too short and does not lock inside, falling off the watch, and I am also not able still to set the hour properly.
While I wait to find the parts for those Landerons, I presented myself with a nice Seiko 7a38-726a which was declared as non working, but I managed to easily fix it. The watch was covered in soil and dirt, so it went through several baths... The picture is of the watch on my lap, so sorry if it is blurry or too dark.
To tell you the truth, it all started with quartz... A Seiko 7a34-7010 I inherited from my father when he passed away, some 4 years ago. It sat in a drawer for a couple of years until I decided to take a look at it, before the battery could eat out the most of the movement inside. Fortunately I found a forum dedicated to this family of quartz chronographs, and the rest is history...
  • Similar Content
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
