Click spring replacement
Pieter
13 hours ago, Pieter said:
I drilled the rivet out. How does the screw get enough grip? The plate is very thin….
The click spring should have a tiny notch that fits into a small hole in the plate. Just a tight screw down will be fine or to be safe a spring washer. (If room)
Hi Pieter, I have purchased these rivets from a company called Accu - heres a link https://www.accu.co.uk/ the rivet I used  is 2mm x 6mm Button Head Solid Rivets (DIN 660) - Stainless Steel (A2)
You can buy the springs from lots of sellers online but I have found some sizes are very hard to come by. They are either Left or Right and the critical thing is the distance between the screw hole and the tag that engages with the hole in the plate. I ended up buying a straight spring and bending it to the required size.  I bought mine from this seller on eBay
eBay - Advanced Search - Shops - Find Shops - Lisa's Pet and Home Store
I can understand why you would prefer to use a rivet but to be honest I found it impossible to splay the rivet enough without breaking the spring, so I gave up and used a self tapping screw which has worked really well.
Good luck !
Edited by Michael20
Good luck !
Thank you for the advise. The frontplate is so thin so i am wondering if a self tapping screw will hold but i will give it a try. Do you know by the way hiw to adjust the hour hand on the fusee clock? Is is a little bit off so i like to adjust it.
Normally the hour hand on a fusee clock is friction tight. When you have the minute hand pinned on hold the minute hand near the center then try to move the hour hand by holding it as near to the center and move it to the place you need it to be. Always move hands from the center this prevents bending the hand and breaking off.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
