Very new member of this forum, I'm just a passionate hobbyist.
The reason why I'm here is that I occasionally found a very useful topic which guided me trough the restoration of an eta 2540 movement.
It was a precious help and the restoration was successful!
Thank you all since now for any further help!
Stefano
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
