Old cuckoo clock music man wire is broken off
MKC
Hi to all! After I got my HAC up and running with great help from here (thank you again!) I have gone back to tinkering with cuckoo clocks and I have a new problem.. I have a 1950s cuckoo with a music box and the music man attachment wire is broken and he needs to be re-attached. (His head was also cracked, but that was easy to deal with .. even if I could not make him look very happy, lol !). I had to deal with quite a bit of rust all over the movement, I have cleaned things the best I could and I need to try to reattach the wooden man.. but how?? I am a total new learner on my own... I assume I have to try to solder the wire attachment? But what kind of solder wire should I use and what temperature etc etc?  (Is there a particular solder iron I should look for as I do not yet own one. I only own and have ever used a wood burning iron, hah.) I don't want to end up ruining the music box as it actually does sound quite lovely despite it's ratty look. Thanks again in advance for any helpful suggestions!! I will attach an image here too. The yellow circle shows the area where the music man should be perched on.
Hi. Soldering is quite straight forward, the main thing is cleaning the areas to be soldered treating with flux and using resin core solder all available fron hardware stores. Soldering irons come in all shapes and sizes. Pistol grip irons , straight tip, spade tip , round tip.  I personally have a seller workstation with four interchangeable tips, probably best value because it covers most bases. But again depends how much you are going to use it, so it’s a cost thing, solder comes in reels or tubes with a few yards inside.
remember to clean thoroughly the joint to be soldered for the best result..     If the point where the wee man fits has a projection requiring a butt joint fit a sleeve over the joint preferably of brass or copper.
Thank you very much! This is very helpful. I will figure out how far I want to go with the soldering. These old clocks are like rabbit holes and cuckoos have turned out to be particularly vexing to me. A new music box would probably be the smartest solution, but that would not have a wooden, cranky looking Music Man with a cracked (but repaired!) head 🙂
Hi originality is always best, to be kept as it was when made with all its bruises and chip/dings. These are all what it gathered in life, I hate as new restorations as they remove the history from the clock.  Plenty of patience will be required and an investment in time good luck  and come back if you need help.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
