Balance becomes sticky when interacting with pallet fork
I've been trying to save this pocket watch which was in a bit of a state when I got it. All parts cleaned, oiled and gresed. Everyting works well with nice power at the pallet fork. When installed on its own the balance spins nicely although comes to a very slighty sticky stop but I have had much worse that still letes the movement work.. I have inspected the jewels (cap jewel for one balance pivot is missing) and all seems fine.
When installing the balance it does move the fork left to right. But it is sticky and will not run. There is friction somewhere but I have spent hours trying to find it. note the hair spring is a bit messed up. I have straightened it as best as I can and as I say when installed on its own the balance spins nicely. Only when it meets the fork does it seem to 'gum up'.
Thoughts appreciated!
Hi there,
 Check if roller  rubs on fork horns, in which case it should run OK if  the movement is flipped upside down.
Check if the guard pin rubs on roller.
Make sure balance rim doesn't rub on fork cock.
Good luck.
1. Impulse jewel is not in plase, move it down and glue it with shellak.
2. Demagnetize the whole balance and the lever. It is of significant importance when the roller and the fork both are made of steel. Here the guard pin is not separate part, it is part of the fork which can not be regulated and should be OK if all is original.
Edited by nevenbekriev
Hi if you are missing a cap jewel the balance end shake is effected and un less rectified will have an adverse effect on the movement ie. If the watch is placed in a position with the missing cap jewel the staff shoulders can rub on the setting and cause all manner of problems.
8 hours ago, Nucejoe said:
I guess just  luck.
The fork horn  might be dirty, clean with a soft  tooth brush in lighter fluid.
The op has inspected the jewels and all seems fine. Except he has a cap jewel missing. I think maybe his "fine" is somewhat different to our fine lol. For things to be more fine that cap jewel needs to be not missing.  Or am i missing something, possibly some diplomacy 🤪
  • Haha 2
Hi matey,
 As soon as the OP flips the movement upside down, all questions in regard to the effect of a missing cap stone, is answered.
There  , however,  remains the point made earlier about  pivot shoulder rubbing on the setting which depends on what side is up what down and the side that still has cap stone and pivot lenIgth.
FYI, I am 100% a meat & potato man, no diplomacy.😄
Rgds
Edited by Nucejoe
18 minutes ago, nevenbekriev said:
OP says that htre balance oscillates OK. It is possible that the missing cap stone is 'replaced' by piece of main spring under the stone plate. It is just a filling that i have...
Thats an interesting solution to a missing cap jewel.  I've seen that recently, discovered under a balance top plate, maybe wasn't here on our forum.  If its a filling you have Nev i think you should speak to HectorLooi,  he used to be a dentist 🤣
Edited by Neverenoughwatches
Had a Patek in with the cap jewel glued in place, missing the (Kif) hole jewel. So the staff was running on the diameter that contacts the setting in event of a shock- but it was actually running!
Have definitely seen bits of mainspring clamped down to make up for a broken or missing cap jewel too.
I have seen an army of baby cock roaches  run every which way out of a pocket watch as soon as  got the backplate opened. 🤣
Nickelsilver,  a day will come, I have success  making you laugh.
Rgds
Edited by Nucejoe
Rgds
Haha, its not a myth Joe, Nicklesilver has pressed that laughing face icon . He might have even laughed at me once ( inside ) . Its making John laugh that's my nemesis , it will happen one day even if i have to go to seattle and beat it out of him 🤣🤣🤣🤣
See, my wife is a doctor, and she is willing to hear about all my feelings... But some of them should be never shared.
About the pieces of springs - it is a common solution used by many watchmakers in the past. And the results are not bad at all, especially when this is the dial side cap stone. I use to call this side 'down' or 'bottom' side of the balance or movement. There are watches made with such plate made entirely of steel instead of jeweled plate on the dial side. A pocket watch is not expected to work in dial down position for a long time.
I can't quite make out if that's sarcasm or not Nev 😅.  And speaking of dentists i bought some of the seperating disks your were talking about a few weeks ago. 👍 brilliant idea and so much cheaper and easier to use than slotting files. Great tip.
This disks can be used to entyrely form and grind figure springs and setting lever springs of hardened steel
Ok Nev, i think maybe the dentist filling joke went right over your head 🙂
I'm not sure if I got it, what i thought is that I may be need to share my feeligs with some psychologist, but if we have not one in the group, then I can use the dentist...
A, now i see that i have typed 'filling' instead feeling. This is my bloody english...
Haha that was it Nev, we got there in the end 😅
They're brill Nev, 0.2mm diamond disks they work great with my new little milling machine. I paid less than £1 each, what is your currency ?
Could you let me know where to get them? I use slotting files, but always on the lookout for alternatives that work.
Apologies if I've taken this thread off on a tangent!
I've had the same on my bench, where the escape wheel cap was shellacked into place and it ran pretty damn well, to be honest
Edited by Jon
Theres a few different types , i went for 19mm solid disk, the diamond continues upto and around the edge of the disk. I'm guessing the grit is around 200ish , a bit rougher than i would have liked. I removed the slot from a small screw and had it cut back in by hand within a couple of minutes of fettling.
https://www.ebay.co.uk/itm/404219193851?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qx1zhgfvseo&sssrc=4429486&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
Its making John laugh that's my nemesis.
Ya John is a tough one too.
33 minutes ago, nevenbekriev said:
My currency is BGN (Bulgarian Lev), which is fasten to EUR, so 1EUR = 2BGN
I am afraid we have stollen the conversation away from the OP problem...
Agree we hijacked this thread.
 I visited Bulgaria 32 years ago, good ice cream,  brought back a few little and cute levas , bought an overcoat for $11، whose price tag I know was $240 in the US. Cheap boose and Doctors visited patient for free.
Doubt if it still as inexpensive nowadays.
Not to mention that piece of mainspring as cap stone, is watch destruction.
Rgds
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
