Hello All;
In connection with the interesting current balance riveting discussion (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/#comment-243895 ), I like to bounce off my "one-off" or "emergency lathe" idea.
I too need to change out a balance staff, this time from a Valjoux 5 chronograph movement.
I've done successfully a balance staff change out before, but on hindsight I wasn't too happy with the way I did it and nearly screwed up the hole in balance-wheel.
Not having a lathe, I could knock the staff out using my staking tool or perhaps use Alum (potassium aluminum sulfate) to de-solve the balance-staff.
While polishing the screw-heads of a nearly finished Le Phare 114CVV chronograph pocket watch, the idea came to me to convert my screw-head polishing tool into a "one-off" or "emergency"-lathe to remove the balance staff rivet-rim.
As some of you may know, I made a variable-speed belt-drive for my Jacot tool;
Using the same setup with my screw-head polishing-tool give this;
With the handle-bearings well oiled, the motor drives the handle very nicely. The two "runners" in front of the tool can be adjusted in height and would double as a nice support for a cutter.
Now I know, there are some "problems", one of them being is that the handle is laying loose in the bearings and could potentially lift-up when the cutting forces are becoming too high. I discovered that, next to the weight of the handle, proper oiling seems to additionally "suck" the handle into the bearings. Also the positioning / angle of the bit will become critical.
But how much force is developed / needed when cutting a balance staff rivet-rim? Also nobody says that the rim has to be cut within 1/2 minute and of course the cutter has the be sharp.
To me there are another advantages, if this were to work for "light" lathe work.
I do already own the polishing-tool and the tool comes with a nice selection of chucks, suitable for nearly all watch balance-staff dimensions and other small items
and I do have already a nice variable-speed belt-drive for it.
Obviously I like this idea to succeed.
Any of you some suggestion on  how to improve on this idea?
Nice idea, but as you say, there are "problems". Being hardened steel, I assume a reasonable amount of force will be required.
How did you do it previously? I too don't have a lathe, and use the K&D tool to punch out staffs. I have never noticed any damage to the holes. As mentioned in the previous discussion, it depends on what the balance is made from. I recently changed the staff on a Longines. After removing the staff I examined the hole under the microscope and could see no marks at all.
But if I had a lathe ....
I don't want to de-rail this thread, but I used my staking set.
As said, nobody said that the rivet ring has to be cut within 1/2 minute. I was planning to cut in small increments. Even if I were to manage to weaken the rivet-ring, that would already be an improvement compared to banging the whole thing through the balance-wheel.
Edited by Endeavor
If the screw head polishing tool was raised above the drive the belt would be pulling down on the shaft, helping to keep it in place.  A plastic sheet could be cut, lightly greased and held against the shaft with elastic, a temporary crude bearing.
I read a post where a soldering iron was used to anneal the staff.
All those (small) things may help, thanks for the tip 😉
That is going to be a bit problematic since the driving unit is light in weight and currently free standing. However, the front bearing of the polishing tool has a recess-groove and since the belt is pulling sideways, the rotating handle is a kind of "secured" sideways. Most likely, it's when the upwards force is higher than the "suction-force" of the oil, the weight of the rotating handle and the "locking-force" of the sideways pull in the groove, that the handle may become "unstable". But to my mind, to archive that force, compared to the size of the rivet-rim, the cutter has to really "dig-in"  ...... 🤔
Edited by Endeavor
35 minutes ago, VWatchie said:
perhaps several ultra-gentle taps with the hammer could save the day
Thanks for the tip, and I knew that. As said, using the staking tool wasn't my preferred method, hence I'm seeking to improve upon that with my "emergency lathe" idea.
I don't want this thread to become an exchange of thoughts which way is the best, we have the other thread, referred to above, for that.
Instead I like members to come up with constructive idea's / recommendations / suggestions / tips etc to make my "emergency Lathe" concept work 🤗
Absolutely, I will respect that 100 per cent! 👍
That would be fantastic and an inspiration, and I wish I could contribute.
  • 3 months later...
Hello, I'm new here.  I like the idea, but use an old balance from a junk/parts watch to test it out.  I'm of the impression that the idea will work well, as long as it runs true enough.
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
