I’m changing out the glass on a6106-7520. The only one I could get was the glass with the gold band (gng) while I really need the silver (gns). Would anyone know if I can remove the gold and use the silver band that came out of the watch?
I don't think that is possible, might be a good time to try your hand at silver leafing, CasKer Co. has some....I don't know if yours is round or not... https://www.jewelerssupplies.com/product10702.html
Fancy Watch Crystal - Domed Silver TrimSED.24.0
$6.95
VIEW OPTIONSFancy Watch Crystals - Wide Silver TrimSE.24.0
$6.95
VIEW OPTIONSSapphire Watch Crystals SSAPH 0.95 Flat Silver TrimSSAPH.35.0
$40.00
VIEW OPTIONS
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
