just a quickie , is it best to remove the stem from a 2824-2 eta movement in position 1 or pulled out to position 3 , i'm having a bit of a job with the keyless works
thanks in advance andy
Use a screwdriver instead of a pointy tweezer to depress the setting lever as this will prevent you pushing it too far. Pushing too far can cause the yoke to slip over the clutch wheel and then you need to do some dismantling to resolve that.
I changed a canon pinion and a winding pinion on a 2804, and I only removed the barrel bridge. After removing the stem and the pinion I had trouble putting them back. So the next time I did that I pulled the stem out from position 2. This way, when putting all back, the winding pinion just stayed on the yoke instead of me having to push the yoke back for the winding pinion to find it's place (I hope you know what I mean).
p.s. @Mark, any more videos on the way? It's been more than a month since the last one. Personally I check your youtube channel at least twice a day.
Putting the watch into hand setting position helps to get it back in without getting everything jumping out of alignment.
I believe there is actually eta tech doc recommending this.
Anil
  • 8 years later...
Thanks for this. It helped me (after making that exact mistake several times).
On 9/29/2015 at 1:23 PM, SSTEEL said:
Yup, a 1.20mm screwdriver will ensure you don't push the button too far down
That's it.
I know that many people have had this happen to them, but strangely, even very strangely, I never have. I always get a lot of weird things that nobody else gets. Anyway, I always use the tip of brass tweezers to remove the stem. I pull the crown out and while I keep pulling the crown, I gradually press the button harder and harder until the stem releases. Maybe the next time I'll get in trouble, so knock on wood. I got used to using tweezers as I couldn't get it to work with a screwdriver the first time I serviced an ETA 28XX movement.
59 minutes ago, RichardHarris123 said:
I haven't had the problem either but I've been amazed just how hard I had to push.
I would say it does depend on how the keyless works are set up, i have had it happen once before. Pulling the stem  to time set mode can also be a problem, that puts the yoke or setting lever under tension from it's spring and without the extra stability once the stem has been withdrawn and the set screw being loosened the yoke can flick over it's spring or something else.
I find that happens from time to time usually its something cheap Rich, and force myself to stop pushing, I've broken a set lever more than once doing this. Dials tight up to the set lever cause this , cheap Smiths are renowned for it. Too much depth in the stem slot as well,I've shortened quite a few yoke bends to make the last job of entering the stem easier at the casing up stage.
I always pull the stem out either one or two clicks. In doing this the clutch has a little more stability engaged against the date setting wheel and is less likely to flip. It's a design fault ETA should have sorted out by now. The ETA 2892-2 doesn't have this problem!
Also when the stem is out don't give the movement any hard jolts, as this sure to flip the clutch and then the yoke comes out of the notch of the clutch. You can sort it out by removing the barrel bridge and reseating the clutch and yoke, rather than removing the dial and hands, etc.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
