Omega 620 troubleshooting help
Hello esteemed members
I recently acquired tiny 22mm omega with 620 movement, non runner. Balance did not move. First I thought oh how easy there's a case clamp screw lodged somewhere in gears as one clamp was running around the insides without screw. As it turned out this wasn't the case as screw was not present at all and mainspring end was broken.
So after installing new mainspring, cleaning and oiling this problem still persists. Balance swings freely when pallet fork is not present.  Pivots are not bent or broken. Roller is in correct position when balace not moving. I noticed there seems to be a very tiny gap between roller table and balance wheel itself but that's likely just how it should sit on staff. Hairspring good. Train on it's own is also moving freely. All the gears are in perfect condition, no broken teeth or pivots. When I offer pallet fork to the movement and manually move it, it's engaging with escape wheel as it should although there's no fast "snap" of the escape. I don't know how to say this properly but it seems to me the action is slower as it should be(might be nothing). Pivots on fork are also in pristine condition just as balace ones. When fully assembled balance wont move on its own, it can be somewhat persuaded with air blower from one side to another but comes to abrupt halt almost immediately. Movement is demagnetized, it wont run in any position dial up down or side. Worst about this is 620 movement is so small I have a problem looking at balance and pallet fork engagement (or non engagement to be honest).
I've seen some cheap donor movements on ebay but I'm reluctant to go that way for now.
What course of action would you recommend? Any opinion would be appreciated
I would check the fork freedom with no escape wheel present. A very light puff of air should move it from banking to banking.
Then I would install the balance, and see how it acts with the fork. That the roller table is not against the hub is troubling- it should be firmly against it. I think this is likely the issue. The roller jewel could be touching the guard pin, or the table itself touching the horns, or both.
I checked without escape and fork was not moving. I could squeeze the life out of air blower and no movement happened. No endshake was present so decided to adjust baseplate jewel slightly(0,02-0,03mm) and check the result. When I put fork back, other jewel on bridge popped out (like stayed on pallet fork pivot visibly loose), bridge not even screwed down, just with slightest pressure from tweezers. First time this happened to me 😞 😞
Regarding the gap between roller table and balance wheel. When I look at staffs for this movement online there's different diameter on staff for wheel and roller so it might be as flush as possible sitting on that flat shoulder to biggest diameter . It's really small and almost unnoticeable. Less than human hair.
Ah I mis-read, I thought there was a gap between the roller and the hub; the hub is in between the roller and balance and it's normal to have a gap there, sometimes tiny, sometimes large, depending on the size of the hub.
Try pushing the jewel back in, until it holds, and if there is no shake, try pushing the jewel in the mainplate down.
If there is any gap between those two I wont be able to tell even under my budget microscope.
no more spare time today and it honestly stressed me out quite a lot. I'll sleep on this, try refitting it tomorrow and just pray this fork endshake is the main issue why it wont run, fiddling with balance and roller is the last thing I wish to do
Fork issue is fixed I believe but case is sadly not solved yet. Refitted the jewel, adjusted height a bit and it snaps smoothly as it should. Light puff of air moves it form banking to banking. There's also some minor improvement with balance. It can move more freely now but still wont oscillate as it should. At most it moves fork twice and then it's more of a banging on it on one side.
Checked the gap again, roller it fitted flush with angled part. gap I saw before is the angled part of the staff in between wheel and roller.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
