I recently bought a Seiko 5 7009 which turned out to only run intermittently. After taking it apart and giving it a clean I went to reassemble but struggled to get the escape wheel and pinion to sit between the jewels. I think it looks like it might be slightly damaged at the top and was wondering if anyone agrees? It's part number 251012 and I've attached some images below.
If it does need replacing does anyone have recommendations of where to find them in the UK, the only ones I can find seem to cost more than a donor non-running movement. Is it a part that is commonly broken or would people take the risk on a donor?
Thanks, James
The pivot has broken off. Watch supplies might be able to help, you will find some at the top of this page click on Resources and just follow. As this is your first post we like new members to make an introduction telling us a bit about yourself and where you life also interests if you wish.
2 hours ago, jamesb said:
Thank you both for the help, I've added an introduction and will take a look at the recommendations
Thank you for your intro.
Escape pivot spins highest speed in gear train thus is the thinnest and break easy.
 To install the new one, do not fully tighten bridge screws in one go, tighten in increments and each time make sure the pivot hasn't jumped out of its hole. Jewels to it must be checked too, when pivot broke it might have chipped the jewel hole.
Rgds
Edited by Nucejoe
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
