Hi
I've started to work on an omega pocket watch the marking on the main plate are 8760 the serial number is 1551552
the number 552 is also marked on the barrel bridge, the train bridge and the balance
No other mark
I've understand that 8760 is an omega patent and not the calibre number so the size of the main plate is 40.67mm or 1.6 inch
The length of the broken staff is between 5.9 and 6.1 mm or 0.239 in but cannot tell exactly because the 2 pivot are broken
Can someone help me to find the correct staff reference I get from borrel DB  STAFF, *UA 11-98* but cannot find any information on this but it mention that the base movement is 17L.
https://www.emmywatch.com/db/movement/omega--8760/
https://www.emmywatch.com/db/part/staff--100_842/omega--17l/
however I'm really not sure
Thanks for any help it'll be a shame to throw away this watch
Edited by richiesgr
  • 4 weeks later...
On 4/14/2024 at 11:26 PM, CYCLOPS said:
we need to see under the dial to finger print hopefully,  there are several 17 ligne Omega's showing, seems they all use different balance staffs.....
Thanks @CYCLOPS and @RichardHarris123
I've not checked under the dial I'll and give you the update if present
