French mantel clock movements - compatibility between "makers" ?
rjenkinsgb
Hi,
a friend has a clock from around the late 1800s, which has a wheel in the strike mechanism that has lost some teeth.
The movement is stamped Vincenti & Cie. I've looked for one of these for a couple of years & eventually found one that looked idenical, but turned out to be slightly smaller.
While comparing the two I found a clear visual distinction between them - the upper pillar is hidden behind the pendulum suspension bracket on the larger one, while it's visible at the side on the smaller one.
Searching ebay further, I found numerous movements that looked identical to the smaller one, but apparently from different makers?
Then one identical in appearance to the larger one, which the seller confirmed was the same ~90mm diameter - but again from a different maker!
I've received that this morning and it does appear that the main movement (disregarding the differences for a different case fitting) is absolutely identical.
Were these all made to standard patterns and the named makers part of some cooperative, or something like that? I was originally expecting each make to be quite different in detail, even if broadly similar in general photos.
The details in these two are just too well matched to be coincidence - even extra hole just above the centre and the dot makings to identify the removable pivot blocks seems standardised??
(These & the slightly smaller serviced one in my intro post are the only clocks I've examined or worked on, so my knowledge is rather minimal)
I will post separately about the damaged wheel and either movement substitution or repairing the wheel.
Thanks, Robert.
Vincenti & Cie movement:
HP & Co movement:
Hi Robert. Like a clown I missed the pictures. Measure the distance between the pivots and the pitch of the teeth  I might have one as I have a drawer with some french clock bits in
Hi Robert. Like a clown I missed the pictures. Measure the distance between the pivots and the pitch of the teeth  I might have one as I have a drawer with some french clock bits in.   Previous repair broken down, as it runs directly on the barrel there is a lot of torque and it broke
I have restored hundreds of French clocks. I know what you are saying that they look alike and yes they do but fitting pats in to another not so easy, there is 9 times out of 10 some difference. As for wheels you have depth, wheel count pinion count, as already mentioned length and pivot length diameter of the wheel and it has to be in the same position.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
