Tissot 781: hour hand not in sync with the minute hand
Hello all, I have a Tissot cal. 781 with a strange problem. Let's say I will pull the crown and start rotating the hands at 12 o'clock, with both hands pointing exactly to the 12 index. After rotating the minute hand around the dial twelve times, the hour hand will now point to somewhere near "quarter-to-twelve" rather than to the 12 index. And if I go on, the "delay" accumulates.
The hour hand however seems to be moving very smoothly, there are no apparent stops, so I tend to believe it is not the matter of friction between the hour hand and the dial.
I disassembled the motion work and inspected the teeth and leaves, none of them is missing and they all look right. I took a picture of the gear, counted the teeth and leaves and the ratio is also correct - a 12 leaf cannon pinion to a 36 tooth minute wheel and a 10 leaf minute pinion to a 40 tooth hour wheel.
What should I look at next?
Doesn't sound like a loose canon pinion. A loose canon pinion results in loss of time but hand are still in sync.
Loss in syncing of hands is usually caused by missing dial washer, loose pinion of minute wheel or hands touching each other or something.
  • Thanks 2
 Oh shoot, I hadn't understood OP's descriptions🙃
OK minutes hand looses 15 minutes every twelve hours and the loss accumulates.
 The two adjacent gears shown above must either not belong to same caliber ( need a vulenteer to do some calculation because I am lazy ) or  a few gear teeth miss pinion leaves which must have gone unnoticed, a vid in slo mo shows this kinda stuff.
 Loose revit of pinion on gear wont by itself explain the accumulation of those 15 minutes , but I check the revit for looseness anyway, it can facilitate gear teeth  to miss pinion leaves.
Edited by Nucejoe
12:36 then 10:40 ratios, looking at the photo.
/3 the /4, so correct 12:1 reduction..
It must be something slipping or skipping due to allignment?
How about other gears in the MINUTE TRAIN? haha.
@MartinOfPrague There are walkthroughs on this caliber on WRT, where you might find a pic of the minute train, good to make sure you have the right gears as far as the Number of teeth. 781 Is originally an ETA with a host of calibers whose parts interfit. Worth a checking In case you found no gear teeth slipping.
Finally a vid in slo mo of the train  might be needed .
Rgds
Edited by Nucejoe
All right, so here is the most likely explanation: one of the dial feet is broken off, therefore the the dial is not well centered and the short tube which is a part of the hour hand probably rubs against the edge of the dial hole. Thanks again for all the suggestions, though!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
