Hello guys, I'm trying to identify a movement for my friend from an unknown brand of the following pocket watch
the movement have the balance broken and me and my friend would love to bring that old guy back to life because this watch belonged to his grand dad and he would love to keep some memories for him
here is the movement we would like to identify
If you could please help in any way with the identity of this movement, it would be very nice and you would contribute to the repair of one of the many exceptional watches that have a really rich history and it would be a shame to let them gather dust. If by some miracle you could also advise us where to buy a balance or donor movement if the parts for it are no longer available anywhere, that would be lovely bonus for my friend
Thanks in advance for reading and sharing your valuable experience and/or advices
It's a five bar pocket watch, cylinder escapement, pin set. It  may be impossible to find the maker.  Measure the diameter of the movement and post photos of the keyless works.  Unfortunately finding spares may be impossible too.
I appreciate the quick replies, I'll try to solve it with a friend that we will have the missing piston made somewhere, because basically the rest of the balance is preserved
Add a picture of the balance parts so they can be assessed.  Dont assume that everything else will be ok, its very likely it wont be. Take it step by step with help from here.
Making a cylinder is extremely difficult, they are so hard it is like glass. They consist of three parts, the center and a plug each end which has the points. Here is a picture so you can see what I mean.
 I have seen tons of  these types of parts( used)  in my late watchmaker's stuff, unidentified , guess he knew them just by looking.
Need full measurements to look for what you need.
Rgds
There are countless movements of this type about, but they are not universal and it is highly unlikely that parts from a movement will fit others.
Rgds
Thanks again guys I do appreciate your effort, the watch isn't in my position so I can't take the measurements, its with the aforementioned friend, I recommended him to buy the exact same watch for spare parts, but I don't know what he will decide to do, I just tried to help him as much as I could
The watch may not be identifiable, even if so watches of this age still vary made by the same maker. Balance parts need to be assessed , if one of the cyljnder plugs are damaged then this part should be easy for a watchmaker to source or make. It is also something he would need to fit and adjust to the watch, not something a something a hobbyist with limited experience should tackle. I tried this myself a few months ago only to fail miserably breaking the cylinder in half, believe it or not i consider i was being very careful 😂
In this case usually a replacement cylinder is installed. There are still many NOS PW cylinders around.
As correctly mentioned, a watchmaker’s task. Different sizes must be regarded,  exact diameter and length being basic but far from sufficient.
Frank
  • Similar Content
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.  Thanks for the link John, it will be interesting to find out how much it costs when they email me back.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
