I have these watches received from a friend. He just sent them to me in a box, in case I would like to repair them. These are from a collection of "stopped working" watches he sent to me. There was a Casio watch which only needed a battery. It was an Edifice I guess. Still didn't show these to anyone as I don't know if it's worth spending money on.
Does anyone have any idea whether these watches are of any known brands or some cheap ones? 🙂
I have reduced the photo sizes to save disk space. There are 3 watches here. 2 pocket watches and one wrist watch.
9 minutes ago, spectre6000 said:
Would need to see the movements to have much in the way of a clue.
I should get some tools and open them up to take photos. Or I'll have to get a repairman to open it for me. Not sure if they would only open them, without a repair job. Shall try anyway.
They are cheap fashion watches, the pocket watches probably have a very cheap quartz movement in them, the wrist watch appears to be a chronograph, which if it actually is, is still probably not worth more than what a proper watchmaker would charge to change the battery.
If you intend to repair them yourself then have a go. If you are thinking of taking them to a watchmaker then the answer is no they are not worth it.
I agree, but as you have no prior experience, start with a large movement either the Unitas 6497 or the Unitas 6498. If you don't want to spend too much money, which is a good idea when you're new, there's a good Chinese clone (I've been told) of the 6497 named TY3600.
https://www.cousinsuk.com/search?searchTerm=CHI3600M
If you are interested in the hobby of watch repair then why not. There is no indication on the dials that can be seen that they contain anything other than quartz battery powered movements. Repairable ?  depends on what the batteries have done inside. Cheap fashion watches will contain cheap quartz movements available for just a few of your low value currency, by far the most time - cost efficient way to have them working again. But by all means try your hand at actual repair, this is where the true value of these lay which is the personal experience to you,  the knowledge and skill you will aquire. Enjoy matey.
While I am not a tech guy I used to open up mobile phones and repair then following instructions on gsmhosting forum. Minor to mid level repairs, not chip level repairs. Couldn't do any recently, but I was able to actually do it.
I usually take photos at every turn, to make sure I won't forget anything, or at least to be able to put them back together. lol.
Thanks everyone for the great advice and tips.
That's an excellent idea! I've been doing this for many years now but I still take a lot pictures.
19 minutes ago, Kalanag said:
Very cheap 😆
Wow very cheap indeed, worth buying to harvest the parts:
  • strap
  • crystal
  • hands
On 4/4/2024 at 1:35 PM, Kalanag said:
Very cheap 😆
Awesome. I can open it up without any doubts that I maybe wasting at least 20 dollars. lol
If anyone really needs this one for any parts then it's yours. I'll open the back and post a photo later.
I did a search and found that one of the pocket watches is a known brand, slightly, from Rhode Island where my friend who sent it is from.
https://james-michael.com/products/pda001004
However I found that the two tiny words (probably like Japan Movt or something) beside number VI are missing in my watch. Also on the half dollar sign of my watch there's 1936 and "In God We Trust".
I feel like Sherlock Holmes now. 😄
    • Well I spoke too soon. Here's where I am now with this issue. I replaced the date jumper and all seemed to function correctly. Fully wound and only in the movement holder, no dial or hands, I let it sit untouched for two days. Both nights it advanced the date. The second night it might have been just shy of fully advanced. Seemed as though I fixed it, so I reassembled the watch. Three nights in a row the date did not advance. Once I pull the crown it does. So you might think that it's the dial interfering, but here's the weird thing. If I advance the date during the day to 11:57p and watch it get to 12:00:30a the date flips with gusto. So here's what I'm thinking and could use your council. I installed a new Swiss mainspring. I used Moebius 8217 braking grease on the barrel walls. It seems to wind quite a bit before slipping, but does slip.  I've read that the 7750 really needs Kluber p125 as a braking grease.  Do you think it just doesn't have enough power after a few to several hours of sitting before the date change? Here are the TG numbers after service:  Rate +1s/d,    Amp 301,    BE 0.0ms
    • I've managed with the ones I have but 1.8 mm would be better.
    • Parts weren’t readily interchangeable when this watch was made, and almost every part was adjusted by hand to fit the rest of the parts in that specific watch. That said, it can save time to harvest a part from a donor movement so you can modify it to fit a similar movement, rather than try to make the part from scratch.  With that in mind, it is possible that the click from this watch was removed for use in another watch. I doubt that the other missing parts were taken for use as donor parts. The cannon pinion would be removed properly, rather than snapping it off with the centre wheel arbour and pin inside it.  The Maltese cross stop works were probably removed by a lazy or less knowledgeable watchmaker servicing the watch.  It is very common to encounter otherwise functional watches (including very high end pieces) that are missing their stop work because a previous watchmaker didn’t know how to set it up when reassembling the movement, or was too lazy to bother and knew that the customer would probably never notice.  It is possible that the stop work parts were taken to be fitted to a watch that was missing them.  Best Regards, Mark
    • I posted a link to another video where he takes it a step further and uses the pins to set and adjust rate as well as positional error.  Alex doesn’t manipulate the stud angle after he pushes it in but I find it makes a difference in the spring concentricity and bend.  Amex also doesn’t use the pin manipulation to adjust positional discrepancies.
    • Brilliant! Very commendable! 🙂👍
