Hello again.
I have been lucky enough to obtain a MUDU watch, inspired by 'Gentlemen' (Thank you). It arrived and I secured the lose rotor and movement holder. Yes, that's all it needed, honest. However I wish to do the job correctly and do a full service.  I has a very good condition ETA 2788 movement.  Timegrapher - 176s,  226 degrees. 1.4ms. 52 degrees running at 21600.
I have been searching, without luck, for a 2788 pats and oiling sheet. I have the 2789, but my internet skills to not seem to be good enough. Can anyone help with a location of a download?
I am pretty sure that I could do the service without, but preparation is the name of the game.
Will keep you all posted with the service.
Toothache still raging. Feels like the electric silver paper shock. Only 10 or 12 times a day now. Dentist say it is a rampant nerve. 5 weeks for an appointment.
Ross
Edited by rossjackson01
Spelling, Grammar
Marc.
Thank you for the prompt reply and explanation.
2788 Date.     2789 Day and Date.     2789-1 Day (2 languages) and Date.
You have given me the information I require. I have placed a notation of the ranfft in my favourites.
I am very conversant with the 2789 and 2789-1 so will easily be able to do the service.
Spelling, Grammar, more information
Ross for parts sheets for all watches, you will find them on Cousins https://www.cousinsuk.com/document,
or another site I use is https://watchguy.co.uk/cgi-bin/files.
The oiling is as every other watch 🤣.  If you need help, see : ETA_2836-2.Asembly and Lube.pdf
One problem I've had with the automatic ETA is the reverser wheels. If you don't lubricate them correctly, the winding can be VERY stiff (or they may just be worn). I always cleaned them and made my own mix of 1/30 9010/naphtha. But I've still had problems - the last watch was very stiff to wind. So I've finally bought some Lubeta V105 - fixed the stiff winding. It's not cheap but will last ages.
Done.
Had a 'ping' with seconds hand. Will redo when I find it. Crystal on order. Boxed up as I wanted to wear it.
-3s. 214 degrees Amplitude. BE 0.1 Happy Bunny.
Update on the Mudu
Finished the service on March 31st. Wore the watch. Decided to clean the case. Guess what? Found the seconds hand in the fold of my working box Wednesday 15 May. Phew!
Look at the difference that I can achieve. Wooho. Chuffed.
  • Like 5
Chuffed for you too, the only thing I'm slightly surprised by is you didn't clean the case in the first place.  When the movement was out of the case, why not clean it then?
Just questions, I really am happy for you.
Edited by RichardHarris123
Typo again.
Did the movement and put it in the case just to make sure I could do the service. Was not happy as I did not have the hand so did not need to finish. When I found the hand I removed it and cleaned the case. Next is the crystal. I'm still learning.
I have received a set of sanding sticks so used them.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
