This video demonstrates how to hold a burnisher comfortably, safely, and efficiently for burnishing a wheel pivot in a Jacot tool—a huge thank you to @nickelsilver, who generously shared this information. I can’t thank you enough! 🙂👍
https://www.watchrepairtalk.com/topic/28602-longines-balance-staff-pivots-are-they-too-flat/page/2/#comment-241887
Edited by VWatchie
  • Like 6
35 minutes ago, oldhippy said:
It's different for me and others who are left handed.
Can't you just rotate the Jacot tool 180° (work on the other side of it) and get yourself a burnisher for left-handed people, for example, the Bergeon 2933D? Perhaps that is what is different or am I missing something? In the video, I do mention there are two types of burnishers for those who are either left-handed or right-handed.
Its not that simple watchie, lefties are wierd kinda folk 😂
We had a young guy in (many years ago..) who wanted to change careers from photography to watchmaking. He worked out an arrangement with my boss at the time to work as a sort of apprentice, for a small wage.
Boss wanted him to learn filing, as one does, so showed him how to hold the file, how to make proper strokes- this was a "full size" file, mind you, all that. Gave him some parts that needed a few licks here and there (like deburring on large stuff) and left him to it. Came back 30m later and all parts were destroyed. What the?!
Boss: "Please show me how you did this"
Kid: (starts filing wildly)
Boss: "That is not at all how I showed you!"
Kid: "But you're right handed- I'm a lefty!"
It definitely wasn't an issue of which-handedness. Ended up he couldn't follow instruction on anything. He didn't last long. And that boss was an absolutely marvelous teacher, very methodical , descriptive, and always demonstrated exactly how it should be done.
Side note: One of the best pivoteurs I know is a lefty. But he actually uses the Jacot with burnisher in the right hand. You guys are a weird bunch.
Edited by nickelsilver
I've considered myself being pretty ambidextrous with my tools, working up a ladder you need to be able reach around and work from both sides of a ladder. After 40 years i can play a tune with a panel saw, can i use it in my left hand ? Can i fook 🤣
I'm multi-handed, not quite the same thing as ambitious, does that make me weirder still?
Haha check your predictive mate , I've already been pulled up for that today, i was being too ambidextrous with my spelling 🤣
1 hour ago, oldhippy said:
Oh that sure is me. 😀
👍thanks OH  just needed you to confirm that for us 😂
Multi handed ?  If you have more than two hands then errrm yes that makes you wierder still Richard in fact extremely wierd 🤪
Edited by Neverenoughwatches
Spelling 🤣
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
