Analyzing with (nearly) constant torque
I posted a link to another video where he takes it a step further and uses the pins to set and adjust rate as well as positional error. Alex doesn’t manipulate the stud angle after he pushes it in but I find it makes a difference in the spring concentricity and bend. Amex also doesn’t use the pin manipulation to adjust positional discrepancies.
By coreymsnow · Posted
That's great info, thank you. I wonder if the guy who owned it, being a watchmaker, was using it as a donor- would explain the missing parts. I'll have to see if I can find the missing parts. Be an interesting challenge. -
Hi Mark, Just read some of your responses/ help , and learned. Glad to have you with us on WRT. Regs Joe
