Hi all,
Happy to join this forum. Just started with some watches and collecting necessary tools for basic maintenance.
Hope to find some nice info here to get me going into this nice hobby.
Greeting from Eise
    • Hi. It’s either riveting or welding . I have seen some small home made welding tools on UTube at times may be I should have a go at building one, they are small spot welding machines. Suitable for the likes of these type jobs.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
