Hi!  First post here...
I'm working on repairing a cheap watch that my friend accidentally took swimming with the crown unscrewed.
After cleaning the case in the ultrasonic cleaner, the bezel is much harder to turn.  Does the bezel click spring need grease?  If so, what kind?  I have Moebius 9415 and Molykote DX.
Thanks!
Edited by BrandonCLT
  • BrandonCLT changed the title to Grease bezel click spring? Hard to turn
6 hours ago, watchweasol said:
I would apply a thin coat of grease, even Vaseline would work. Remember to oil the spiking and plunger.
Thanks! I’ll try some Molykote when I get back home on Monday. I’ll report back with an update.
One thing to keep in mind is that grease attracts / accumulate dirt / sand etc. It may work in the short term, but could become problematic in the long term.
The Molykote seems to have worked the trick.  I greased only the spring/plunger and every other detent on the bezel
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
