Here is a 4-jaw chuck I recently acquired as part of a lot.  The jaws need a tool that has a square socket and small diameter to fit in the hole.  What would you call this tool?  Where would I find it.  I guess I could try to make it.  But, I dont want to. The chuck is made by HB Dale.
image.png.400278396bee1e886ab099c2e6129ffb.pngimage.png.5e7c15e17e62d479a018320cc5520920.png
Just now, HectorLooi said:
I simply used a Philips screwdriver and ground the tip flat. Works quite well.
Hmm, I am having a hard time visualizing that. The tool needs to have a square recessed region to go around the square post, no?
7 hours ago, HectorLooi said:
Ahhh. Yours is a girl, mine is a boy.
The square post is 3mm x 3mm. The body of the tool must have a diameter less than 5mm...maybe less.
Clock key is a good idea.  However, the body will be too big, so I will have to turn it down.
