Different shapes are used to open the watch case back. For example rolex has a different way. Are there specific names for each of these case backs? Who creates these unique shapes? I want to know if there are special names for these different shapes. For example, how to call rolex case back?
  • 4 months later...
I've been doing this for several years now but never heard of various names for case backs, except for "screw on" and "snap off".
That type of case back is called - and you probably guessed it - Rolex case back!
unfortunately in watch repair there is lots and lots and lots of variations of things including casings.
for instance if you ever purchase anything from old watchmaker estate stuff for instance it often find handhelds case wrenches for specific case back's. You'll soon accumulate a small collection that you probably never ever use almost popular for some particular case back that probably doesn't exist anymore. All kinds of  shapes and sizes.
Here for instance is a rather expensive one but you can look at all the examples and get ideas of what exists and there's even a video.
https://www.esslinger.com/horotec-maxipress-07-363-deluxe-watch-case-opener-with-dies/
found another informative video notice initially the universal pieces that he says will open almost anything? I would be really careful with Rolex cases of using anything that is generic it's only making contact in a couple of places it works much better if you've something that makes contact all the way around. But little farther in he goes into the different parts that are compatible with this one.
then unless we find the catalog page that shows all the die is there currently available I don't think there's any real place where you can find a listing as there would just be too many of them.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
