@andygsi initial plan was to work with existing movement as a learning session. Since the common thought was replacing unit i will do that. I think i will keep old movement and learn with it and buy a new one for the watch
By luiazazrambo · Posted
It seems like the shaft was weakened by a cut, probably this was the reason why it broke here. Considering that the missing bit has the following parameters what would you suggest for the drill/hole size for the new bit? -
Nice. Yah then the intention is to unscrew the crown if yo can get some purchase on it. How much of the back can you expose?
