1 hour ago, Knebo said:
I can't say that I'm overly happy with the overall image quality, but I think it may be primarily an issue of top-down lighting which causes reflection and over-exposure. Perfectly fine for taking pictures for technical/logging pictures, but not great for artsy ones.
I use the same light ring and 0.5 Barlow lens as you,  and find it an excellent combination. I have the same reservations on the pics - reflections, over/under exposure.  For more 'artsy' pics I sometimes shine a more yellowish desk lamp or torch from the side. Still not great though.
I'll try that. Thanks!
Thanks to all of the information gleaned from this post (and a couple of excellent YouTube vids), I took the plunge today and ordered a Microscope from AmScope and camera from AliExpress. Here's what I ordered:
AmScope started a Black Friday 15% Off Pre-Sale today (enter PRE15 coupon code at checkout), so that was a pleasant surprise. AliExpress pricing was also lower today.
The two videos I found most helpful were from:
I'll follow up with a brief review once I have some bench time with the new gear.
Cheers!
--Rick
Cheers!
--Rick
I think this is a perfect shopping list. Surely also useful to others.
Once you receive you equipment, you'll need this video:
44 minutes ago, spectre6000 said:
I would amend that list with the double arm boom stand if it were me.
@RickTock's order includes the Single Arm Boom Stand in the Amscope order. So it would be rather "replace" than "amend".
I have the Single Arm and haven't faced any problems/constraints with it. What's the advantage of the Double Arm?
15 hours ago, RickTock said:
That's what I need! My camera is on the existing mounting, on a 0.5X Barlow. It sits way too high, and doesn't get enough image. The 0.35X looks like it would be perfect.
99% of the time I'm working  under the 0.5X Barlow. When oiling pallet jewels, or if I need a close inspection of a pivot, jewel, I used to remove the Barlow. Which is fiddly. So I bought a pair of 20X eyepieces. Seconds to swap and you get the same magnification (though you do lose field of view and brightness). I bought a cheap set from ebay.
1 hour ago, mikepilk said:
That's what I need!
Yes you do! 😄
That's a smart alternative! I also do the screw-off, screw-on procedure -- which also means that you need to lower the scope and then lift it up again. Indeed takes a lot of time.
Question @mikepilk: if you exchange the eyepiece, do you need to adjust the height of the scope? Or does the distance to the object then remain the same as with the 10x eyepiece?
Edited by Knebo
2 hours ago, gpraceman said:
Why remove the Barlow or swap out eyepieces to oil the pallet stones or do inspection?  I just zoom in.  I am using a 0.5X Barlow and 10X eyepieces.
I think what @mikepilk and I are referring to is where you can benefit from even more zoom. He said:
And it's the same here.
I think 0.5x barlow, 10x eyepiece and the 4.5x maximum magnification of the main lens add up to 22.5x total magnification. That's more than enough for 99% of the time.
But I do sometimes want that full 45x magnification (i.e. 10x eyepiece with 4.5x mains lens, but no Barlow). For example, when I want to really see the surface smoothness/roughness of a pivot to determine if my work on the Jacot tool was effective.
Exactly @Knebo. 99% of the time I don't need more magnification, but for instance today, I was oiling the pallet jewels on a small ladies movement, and the extra magnification makes it much easier.  There's even times when I put in the 2x Barlow to give me 90x mag if I need a really close look at balance pivots.
Can you confirm @mikepilk
9 minutes ago, Knebo said:
@mikepilk I wonder... if you could confirm: How does the field of view compare between 10x without barlow and 20x with 0.5 barlow.?
It's the same.
Fully zoomed out with 10x eyepieces and 0.5x Barlow, the FOV is 70mm.
Removing the Barlow, the FOV is half, i.e. 35mm
With 20x eyepieces and 0.5x Barlow, the FOV is also 35mm, but the image is less bright.
I have the Amscope 144 LED light ring. When oiling pallet jewels or looking closely at pivots, I sometimes use a hand held LED light to increase brightness. For pallet jewels, I sit the movement holder on a small mirror and shine a light on the mirror under the movement, so I get back lighting in the jewel.
24 minutes ago, mikepilk said:
It's the same.
Cool. I just ordered a pair of 20x eyepieces 🙂
Word choice correction is correct.
The double arm stands have a better mechanism for tilting the head slightly, and giving you an angle onto the work piece rather than directly from above. Gives better tool clearance, and can help with glare and angles. It was discussed many pages back, and I can't take credit for the observation of the feature or enumeration of its benefits. I can attest that the stand and feature are very nice and nice to have.
That’s what I did as well- works great!
Hmm, who understands camera lenses ?
The 0.35X Barlow arrived today, but the results are not what I expected. I have a generic Chinese camera, I can't remember what the specs are.
On minimum zoom of 0.7x I cannot focus the camera. The Barlow has it's own focus setting, I can only get a clear image with the focus all the way out.  Then it only focuses at a zoom of about 1.6x, giving a FOV of 20mm (normal 70mm).
I can get it to focus at 0.7x, but to get a clear image I have to  unscrew the camera from the Barlow by about 3mm. This give a FOV of about 50mm, which is fine. But when I zoom I have to refocus, and above about 1.2x zoom it won't focus at all.
Rather disappointing, and I'm not sure if there's a fix. Anyone?
Ah damn, so sorry to hear that @mikepilk. That's indeed disappointing.
I guess there are two aspects of the issue:
1. Not being able to focus:
I really don't know why this would happen. Hopefully others can weigh in. I don't know if microscope and c-mount lens need to be specifically compatible with regard to the exact lens distance... Possibly the "original" AmScope lens will fit? Or at least the "real clone". I noticed that yours just looks a bit different in design.
2. Small field of view.
Here I may be able to offer better advice. I had forgotten about this, but remembered when you shared your bad luck. Sorry that this comes too late now. So... the sensor size of your camera and the (de-)magnification of the c-mount lens need to correspond to give the desired field of view. So first, you need to find out what sensor size your camera has. Most common sensor sizes are 1/2" (then take 0.35x c-mount) and 2/3" (then take 0.5x c-mount). Here is a detailed article that explains it better: https://www.microscopeworld.com/p-3341-microscope-c-mount-field-of-view.aspx
Hope you can figure it out.
Cheers,
C
I believe you need a spacer. I forget the exact whys and whatfors, but it's something like a 5mm spacer for going from one standard to another... Hopefully someone else can weigh in on the reasoning or provide a link.
I looked through my orders on Amazon and Ali-X, and don't see it. Might be @gpraceman had a spare to throw my way or something, and he knew the reason and solution, which is why I'm not coming up with it. Could also be lack of coffee...
Spot on @spectre6000. I tried holding the camera just above the Barlow, and I could focus and zoom and keep focus.  As you suggested It seems about 5mm would do it. The thread on the camera can be screwed out, but not quite far enough. There's plenty of cheap spacers on ebay - I guess one of these would work?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
