I would suggest for the drill use a size 58=1.07mm then turn the pivot to the size you need after fitting the part that way you can be certain that the pivot is concentric with the rest of the arbor. Dell
@andygsi initial plan was to work with existing movement as a learning session. Since the common thought was replacing unit i will do that. I think i will keep old movement and learn with it and buy a new one for the watch
By luiazazrambo · Posted
It seems like the shaft was weakened by a cut, probably this was the reason why it broke here. Considering that the missing bit has the following parameters what would you suggest for the drill/hole size for the new bit?
