That will need to come out the front, the dial is bigger than the movement.
If the case has a removable bezel then take that off, if not then remove the crystal. Everything should then come out through the front of the case.
ok, have you try a watch that twist the bezel to open it? and use what tool?
I try to pry the bezel and it does not work.
    • Thank you Mark it definitely makes the site looked much nicer. Although I didn't mind the ads as long as it helped to pay for the messageboard but sometimes when you had the feeling that there were more ads than message board yes it was a little annoying. Thank you
