Hi there - recently picked up this watch to practice on. Crossed my mind that I'm not sure how old it is, and if it's 60s or earlier might have radioactive lume? Don't have a Geiger counter and am hoping someone can identify and weigh in please. Dial says "Cornell", movement says "Shriro watch Inc", case back inside says "TK Co, made in France". Any info would be helpful and much appreciated please, thank you!
Sometimes you can see a burn mark on the dial from hands that have stayed in one place for decades, which is a clincher, but I don't really see that here.
An inexpensive detector could let you know for sure, but considering the dial/hand style and the darkened condition of the dots on the dial in the absence of any clear water damage, I'd give 90% likelihood that there is radium there.  Tritium is usually marked out on the dial, and although it moves to yellow and tan as it ages, it doesn't get as "toasty" as those dial spots based on what I've seen.
Definitely worthwhile, if you are working with old watches - just be sure it's an actual Geiger counter, not one of the vast range of scam/fake "Radiation detectors" on ebay & amazon etc. that detect RF or static electricity...
In the mean time, I'd put the dial and hands in zip bags & wipe down the work area with a damp cloth to pick up any dust, then discard the cloth.
The emitted radiation from radium lume is not normally harmful - but inhaling or ingesting a single particle of the material can cause serious long term harm, so do take care with it.
Thanks all. I had ordered a Geiger that's showing up today but was hoping someone might be able to identify the watch to help me get ahead of it, so thank you Geotex. I in no way planned or plan to risk my health over watches and will probably trash this to be safe, it just stupidly didn't register for me how old this watch could be before I had opened the thing up. Sticking to explicitly newer watches going forward.
The counter I ordered is a GQ GMC model, which I have seen mentioned and used by many people and seems to be legit. https://www.gqelectronicsllc.com/comersus/store/comersus_viewItem.asp?idProduct=5786
Edited by kr2
Adding info about Geiger counter purchased
Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....
And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
Edited by kr2
Typo
  • Sad 1
To be honest,I would not rely on cpm for a measurement, particularly with radium. The radium is a particle radiation and this cannot penetrate the skin. It has to be ingested (i.e. inhaled) to have an affect. A more reliable measurement of this kind of radiation is the Sievert, which, roughly, is the affect of radiation.  Broadly speaking, when dealing with radium, precautions such as breathing equipment and removing radium in a fluid is advised. Disposal is also something to consider. It's generally a pain in the arse to dispose of and you are better just leaving it undisturbed
Isn't it most correct to say that the mixture of radium decay pathway compounds found in old lume will produce both alpha and beta particle radiation as well as gamma rays, so it's over-simplistic to dismiss it all as low-energy particle emission? True, a cheap geiger counter chirping away with a raw CPM count won't specifically give you the relevant biological dose, but it makes it easy to tell the difference between your local background, a watch with a bit of activity, and one that is comparatively quite active. Each person can make their own risk analysis based on their understanding and concern, but there's nothing wrong with using an inexpensive meter to help make the determination.
Here is the radium decay chain, as you can see it decays into alpha emitters until you get to lead, but it's first decay product is radon with a half life of 1600 years, so  we will all be long dead before the radium on our watch starts emitting anything we need to be overly concerned about.
But the radium wasn’t pure when put on the watch, so it’s already a mixture. We certainly can see counts from watches that penetrate materials that would stop alpha radiation. Again, I’m not paranoid about it, but it shouldn’t be completely discounted when people ask about it.
Edited by Geotex
 As a hands on nuclear power engineer, I have been exposed to what's regarded by ( US nuclear regulatory commison) as forbidden dose of radiation of all sort, can say more than any watch repairer will  possibly be exposed to in his entire life.
Comment from OH is funny, cute and true,
                         " you won't glow in the dark "
                Try not to inhale or ingest any emitter.
Edited by Nucejoe
spelling
Hang on - isn't that misinterpreting the diagram? It's radium itself that has the half life of 1600 years. Hence radium-containing paint in a watch from 100 years ago is emitting almost as strongly as when new, even though the additives that generate visible light have degraded.
The diagram shows that once a radium atom decays, the subsequent chain happens relatively quickly, including passing through two unstable lead isotopes and various alpha and beta decays before arriving at stable lead.
I'm not commenting on safety, but if you can detect alpha then I think the diagram shows that you can expect betas are also being emitted. But I'm no expert...
Nuclear decay emit high energy stuff that can be dangerous, not atoms.
Long half life is scary because they literally are astronomical or infentisamlly small and beyond our comprehension. but  by themselves don't necessarily have to do with health hazzard, in fact there are nuclei whose half life is longer than life of this universe, few of such nucleus happen to have disintegrated so far, that's how we know such decay happens.
Dose by itself isn't necessarily hazardous either.
There are dangers beyond our control. A gamma bursts of a supernova, if it hits the earth will instantly wipe life off the earth, we be dead perhaps thick smoke  before we notice it hit us, say in a billion billion billion th of a second, so there is no point building detectors to warn us, unless you want to station such detectors trillions of miles in outer space, but with current knowledge we call physics , gamma burst will hit us before we receive the first signal from our detector.
Type of nuclear interaction or electromagnetic energy isn't  always a health hazzard either.
Actually we are the product of such calamities or should we say mishapps that has  happened in the past, without which life and this planet that hosts life wouldn't have been assembled by what we know as forces of nature, and  extinction of many forms of life was necessary and became the ingredient  for development of us the homo sapeans  on earth.
Isn't it silly to worry about things which even if we can and do control them, poses little hazzard to us?   many already are, as there are countless forces which can instantly end life on this planets for good.
A question on my mind for years is;
  is life the ultimate product that universe can manufacture?
Undoubtedly there are billion of trillions of planets that currently host life, and more are fine tuned and ready to host life.
Hard to conclude life is the ultimate product of the universe.
And we with our poor incapable mind, unaware of what universe might do, are looking for things to worry about.
Life is a gift, enjoy it without, killing, bombing, worrying ,,,,,
Best wishes
Edited by Nucejoe
grammer
Right! Let's break out the radium energy drinks and toast to that.
Ha ha ,    I let you go first,  you,l glow in the dark. lol
As said many times before,  not ingest nor inhale.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
